SOURCE: Set CD Clock Radio for Daylight Savings Time
I downloaded the manual from the Timex website give in a prior post.Here is a link to the manual in PDF: http://www.mediafire.com/?cn1kusjfosx
SOURCE: Times T309TT Daylight Saving time autimatice setting
Go to www.timexaudio.com and search the user's manual on site.
SOURCE: Daylight saving time auto change over
I have a cube-shaped, silver Timex alarm clock that plays CD's. The fact that it springs forward and falls back on the WRONG schedule (because of the changes in DST) is a big problem, evidenced by this morning...my clock "fell back" and it thought it was 6:30am instead of 7:30...I was awakened 1 hour LATE (i.e., at 7:30 real time, instead of 6:30). The manual says "if you live in area that does not use daylight savings time, you must reset the clock when automatic adjustments occur." It doesn't let you change time zones. I'm just going to have to buy a new clock, when this one is perfectly fine otherwise. Frustrating.
SOURCE: Need to update daylight savings time date
This is from the Timex FAQs site:
Q: My clock did not update for DST.
A: We apologize but there is no patch available. Consumers must change clocks manually. Due to newly enacted government regulations, effective this year you must change the time manually, since the calendar was programmed to change according to the time DST issued by the government, it will not recognize the change after 2007. Now the time must be changed 4 times. Press & hold the time set button until the time flash, then release it and press the ff >> or << rev buttons.
SOURCE: change day light savings setting on old t311t
It won't understand. It was mfg before the new change
