My HK202 simply stopped working all of a sudden! I was in the middle of a call, and the headset said "Battery lo-" and I was cut off. Tried charging it, but the LED won't come on! (Charging led, turned on led, nothing) I left it charging overnight, and nothing still. What could have made it stopped working so brusquely?
It is possible that the bluetooth connection being cut midcall to have froze the bluetooth headsed, one thing you should try is to power it up in connection mode and see if it works, there are different combinations of buttons, assuming you have power and volume buttons to do a hard reset to it... otherwise i think you should take it where you bought it and ask for solution even if warranty period is over because it simply isn't normal what happened.
best of wishes and hope i helped. good luck
SOURCE: When i put my headset to charge it stops charging after 5 seconds
if you are using the USB port on the computer to charge it, it may be an issue of your computer going into "Power Save" mode and shutting down the USB power. I found this by google searching "usb power save mode"... Possible Fix: 1. Click on "Start" and then right-click on "My Computer." 2. Click on "Properties" and then on the "Hardware" tab. 3. Half-way down on the right, click on "Device Manager." 4. Click the "plus" sign in front of "Universal Serial Bus Controllers." 5. Double-Click on the first "USB Root Hub" (not USB 2.0 Root Hub). 6. Click on the "Power Management" tab. 7. Uncheck the box that says "Allow the computer to turn off this device to save power." 8. Click "OK" and repeat for all other "USB Root Hubs." 9. Finally, close all and go back to the desktop.
SOURCE: I'm charging the headset and
When the headset's battery is fully charged (about 3 hours), the indicator light is steadily lit in blue
SOURCE: Motorola HS850 Headset gone silent
I bought a new HS850 and guess what, I got this hearing problem on the very first day ...phew ! I did the pairing with my Motorola A1200 phone and it worked for once, even the sound was coming in the earpiece and then I put it to charge for the first time and once done, I again started it up and it got connected with the phone and after that there was no sound in the ear piece. I was going nuts....about what could be the problem.
So i decided to delete the earlier paired profile from my phone and do the pairing again and guess what...It Worked....:) So you can try that out too....
