Removing my seat
The Key Entry should be a plastic piece underneath the seat, sometimes difficult to find, usually white. You use the same key as the ignition, and turn a 1/4 turn and it will unlock, allowing you to lift the seat off. If it's broken off, you should be able to pull the cable.
Or you can carefully lift the seat up a hair and use a screwdriver to locate the plastic clasp, although this method will most likely break the locking clasp leaving you without a means to secure the seat.
FYI, Most bike shops can locate the clip within a few minutes and are happy to help a new customer, easy fix for them.
