Question about Samsung SyncMaster 204B 20.1" LCD Monitor
Display problem Power is ok not display come
ERROR CODE 0xc19a0002
Switch on your printer.
Press and hold the * key.
Press the # key and release both keys.
Display should say Enter Special Key Combo
Press and releasethe key in sequence 1, 2 and 3 buttons.
display says "support" R0631M
Press and release the right arrow button until the display says " System Configuration Menu".
OK button.
Display should say Hardware failure status. If not there already, Arrow Key over to Hardware failure status
Press and release the OK button.
Display should say Hardware failure status: Clear. Press OK to clear.
Press and release the OK Button. Message changes to Hardware failure status Cleared. Press Cancel to continue.
Press and release the CANCEL button as many times as necessary, so that, either the Welcome to Photosmart Express screen appears, or, the Ink System Failure screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Turn the unit on. The printer may display message USE POWER BUTTON TO SHUTDOWN THE PRINTER followed by PRESS OK TO CONTINUE. Press OK. The Printer will start the ONE TIME INK INITIALIZATION PROCESS. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page..
Oct 11, 2013 | HP C6280 Photosmart All-in-One Printer...
Tip
How to reset an HP printer waste ink tank aborber (only work on certain models)...
Press and hold the “left arrow” key.
Press the “Setup” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release the “OK” button.
The Display should say “Support” and display the FW rev (something like R0616R)
Press and release the right arrow button until the display says “System Configuration Menu”.
The display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
The display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears.
Turn the unit on. The printer may display the message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”.
Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
on Jan 02, 2010 | Office Equipment & Supplies
0xc19a0002
OK button.
Oct 10, 2013 | HP Photosmart C6280 Printer
No display
If power problem then check you power connector. If power ok or display problem then you follow instruction:-
> Check CPU power, proper coming or not.
> HDD on or running ok conduction, if HDD not detect proper then not display.
> Check RAM slot or RAM ok conduction.
> Disconnect all power supply and some movement wait then reconnect all section and power on.
I hope display coming.
Thanks
Sep 09, 2013 | ViewSonic Computers & Internet
Motherbord run but not dishplay
MY DEAR FRIEND
CAN you tell me the what is the display problem
OK
Apr 11, 2011 | Intel Motherboard
No display but power on ram ok cmos battery ok cpu fan and cpu ok
first check ur display cable for breakr if you have built in display disable it in bios and and if you have addon display card remove them insrert a new addon diplay card if you have display the display section in you motherboard is faulty or diplay add on card is faulty if it still dont work the clock and reset section in your motherboard is fulty to find the at the above section if you have a multimeter check the pci slot A15 means the pci pins facing the processor must have 5v if this is ok your motherboard is ok and the problem is with your display card
Oct 07, 2010 | Intel D845GVSR Motherboard
Failure to print
Please follow the below steps.
STEP 1.
Please take out all the cartridges and clean the copper contacts with the help of a lint free cloth and the water.
STEP 2.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 3.
Reset the All-in-One to the factory default settings by using these instructions:
1) Press Red Eye Removal & Print Photos button simultaneously
2)Enter Special Key Combo is displayed on the screen.
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Display should say "Support" and display the FW rev XXXXX.
3) Press Right Arrow button untill "Reset Menu" is displayed. Press OK.
4) Press Right arrow untill "Semifull Reset" is displayed.
5) Press OK.
Arter all these steps, if the issue still persists, please follow the below steps.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
1. Press and release the “OK” button.
2. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
3. Press and release the “OK” button.
4. Display should say “Hardware failure status: Clear. Press OK to clear”.
5. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
6. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
7. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
8. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
9. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
Apr 18, 2010 | HP Photosmart C6100 All-In-One Printer
Blank display no functions power ok
Not sure what you mean by "power OK",
If you have checked that the logic circuits are getting a clean 5 volts DC THEN the power is OK. This requires an oscilloscope AND a voltmeter.
USUALLY when a display shows characters like that it means the processor hasn't initialized the display. Most common problem is too low power supply that doesn't permit the processor to come out of reset.
Bad filter caps can cause the 5 volts to dip below 4.6 volts which would be minimum to operate. A voltmeter might still register near 5 volts but a scope will show the voltage dips.
Jan 12, 2010 | Alesis Sr 16 Stereo Drum Machine
No display in my intel d945gcnl but power is on
check first your RAM memory and your video card. if ok all. try another ATX power supply.
May 29, 2009 | Intel Motherboard, 945GC, Core 2 Duo,...
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
35 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
