Hitachi ULTRAVISION L42V651 42 in. LCD HDTV Logo
Posted on Jun 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tv has green, red, blue, and yellow halos on screen??
Model: 43UWX10B
I took this model # from Graphic Guide..I've had no luck finding manual.
I don't have cable and need to know what to do to access local channels with this new conversion to digital TV.
Your help is greatly appreciated.
Anonymous
Level 3:
President:
  • Master 1,077 Answers
  • Posted on Jun 13, 2009
Anonymous
Master
Level 3:
President:
Answers
1077
Questions
Helped
774662
Points
4687
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 03, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3152
Points
I think my color tubes are off took off the back the colors shine on the celing only blue and red there all got strong color but the green dont show up with them
3answers
Screen is flickering after changing tv configuration on settings page
If you've changed your Wii's output setting to 480p but are still using the regular red/white/yellow cable, that could be the problem. 480p output is only possible using the component (red/white/red/blue/green) cable.
2answers
I CANNOT MATCH THE RED/YELLOW/WHITE COMPOSITE PLUGS TO MY DYNEX 40' TV. I ALSO DIDN'T GET A USER GUIDE WITH THE DVD PLAYER, ONLY A QUICK START GUIDE.
Hi the link below will talk you to the manual http://www.manualowl.com/m/Vizio/VBR120/Manual/157593
Hi I'm not 100% sure what dynex model you have however i am aware that not all models have the red/yellow and white composite plugs. So you best bet is to use an hdmi cable it will give you best picture and can be brought of ebay from £3. If the tv as a scart plug connector, you can get a red/yellow/white adepter to Covent it to scart like the images below:
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
1helpful
3answers
My hitachi model 43uwx10b has magic focas problem's red,green,blue and yellow are moon shaped across the screen
The two STK CONVERGENCE CHIPS AND ANY BAD RESISTORS AROUND THEM WOULD HAVE TO BE REPLACED.
Typical cost for all the parts on EBAY or Suburban Electronics would be under $25.
SD TECH
1helpful
2answers
Hitachi TV, has red ghost lines outlining image on screen! Help!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
1helpful
2answers
Phillips Model 60pp920217f
I expect the answer to your question is YES! The convergence amplifiers are a common problem in many projection sets. When you search for the replacements you should find that the originals have been superceded by improved parts. Also be aware that when these parts fail, they will usually damage a resistor in the convergence yoke return path. The resistor must be replaced with one of the correct value or the convergence, though responsive, will be out of range.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
No. your problem is related to the coolant in the green CRT has congealed with bacteria and needs to be changed. Thats what causes the halos and general poor picture and color quality. The blue should be changed also. The red for some reason doesnt seem to be affected by the bacteria problem. This is a common problem that happens with all projection TVs phillips and magnavox TVs
My phillips model 60pp920217f has a horrible picture...no green to the color
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
