electric ignition module is bad, or maybe the safety shutdown relay, also check to see if the timing belt has snapped, it happened to me, lol replaced plugs, wires, coil, ignition module, and turned out to be the timing belt had snapped causing the safety shutdown relay to shut off power to the coil and fuel pump, good luck :)
Seven blinks - High voltage shutdown. The
high voltage has exceeded 33k and the unit goes immediately into
safety shutdown. Check power supply regulation and horizontal
circuits.
There is a High Voltage fault or power supply fault. Hope that helps.
circuits.
this is a high voltage shutdown.......the high voltage has exceeded 33k,.....it causes the unit to shutdown for safety.check the power regulation as well as horizontal circuits.hope this helps
hello
shutdown. The high voltage has exceeded 33k and the unit goes
immediately into safety shutdown. Check power supply regulation and
high voltage shutdown. you have for some reason experience a voltage higher than what it is supposed to be. this is in safety shutdown mode. i would look at power supply or horizontal circuits.
hello .High voltage shutdown. The high voltage has exceeded 33k and the unit
goes immediately into safety shutdown. Check power supply regulation
and horizontal circuits.
hello. High voltage shutdown. The high voltage has exceeded 33k and the unit
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
