Kipor Ig1000 Generator Logo
A
Anonymous Posted on Mar 10, 2014
Generator overload light flashing
When i start generator overload light keep flashing
Yamaha 2400IS Generator goes to overload when ie: 240 volt plugged in, or 700 watt angle grinder plugged in.
No idea but somebody else will probably come along with a better idea then mine, seems a lot of these generators have this thing installed on them (Has $25 hard start kit). Not sure what it does or how it works. Strangely enough you said you use it for 240 volt. Looked at the picture and didn't see a 240 volt connection.
If you are using the what look like the 120 volt circuits you can't over load the unit. Maximum current draw will cause it to go into protection mode and shut down the power load. The following is an exert from the owners manual which I got from Yamaha's site. Link at the end of this post.
Hope this helps
16
q
760-029
AE00788
Overload indicator light
The overload indicator light
comes on when an over-
load of a connected electrical device is detected, the
inverter control unit overheats, or the AC output voltage
rises. The electronic breaker will then activate, stopping
power generation in order to protect the generator and
any connected electric devices. The AC pilot light
(green) will go off and the overload indicator light (red)
will stay on, but the engine will not stop running.
When the overload indicator light comes on and power
generation stops, proceed as follows:
1. Turn off any connected electric devices and stop
the engine.
2. Reduce the total wattage of connected electric
devices within the application range.
3. Check for blockages in the cooling air inlet and
around the control unit. If any blockages are found,
remove.
4. After checking, restart the engine.
http://www.yamahamotorsports.com/assets/service/manuals/0/LIT-19626-01-23_1423.pdf
Champion 71000i generator overloads
Can you provide more detail on this? Such as under what conditions it overloads, and how much power you're drawing off of it? Keep in mind that generators have two ratings: Sustained Load and Peak Load. Mine, for example, can handle a sustained load of 1,750 watts, and can handle short-term peak loads of 2,000 watts. Note also that if you're running a microwave, they take a lot. So does anything with a motor in it (refrigerator, etc) on initial start up. Once you've added up all your loads, adjust to where you're within your generator's sustained load and you should be fine.
1helpful
2answers
Generator will not stay running
The toggle switch automatically resets all faults when it is turned to the off position. I would turn the toggle switch off, turn off the breaker on the generator and then turn off all the loads in the house except a few lights. Turn the generator breaker back on, then turn the toggle switch back to automatic. If it starts and stays running, you were overloading the generator. Turn on other loads slowly and keep track of what is on so you don't overload it again. If it still does not stay on, you may have a problem with the panel. Let me know what happens.
My kipor KGE 6000 Ti generator overload light is on, and there is no current output
Speak to us and we can help you diagnose this error.
www.generatorguru.com
2helpful
Generac generator on auto runs weekly. light green previuosly green. now red. what causes this??
Hi and welcome to FixYa I am Kelly. Your red LED is telling you that it was 1. overloaded. 2. has low voltage 3. overheated or 4. short in the powered circuit.
OVERLOAD LED (red): Lights up if the generator experiences
a load greater than the rated output, low voltage, overheats or
the powered circuit experiences a short. The output is stopped
even though the engine keeps running.
I do not know which of the 4 conditions caused your red light. If you have the read light with no load I would suspect low voltage from the generator / inverter. If it overheated you will also get the Red LED with no load.
Thanks for choosing FixYa.
Kelly
1helpful
My kipor KGE 1000Ti starts fine but after several minutes stops generating and the red overload light comes on, with the demand for power left connected and the generator still running electrical...
You may be UNDERLOADING the generator and it may be unstable with such a light load... see if it might behave running a heavier load... put a 100 watt light on it as a test,
I have a Honda 7000 EM inverter generator. When it starts after a few seconds the overload light comes on and it shuts down. What is the problem?
ARE SURE ITS THE OVERLOAD LIGHT AND NOT THE NOIL ALERT? IF ITS THE OIL ALERT ITS CAUSE YOUR LOW ON OIL OR THE SENSOR INSIDE THE GENERATER IS BAD?
1helpful
E29 Trouble Code for a Honda Generator
Honda is pretty tight with the codes. You have to call a 'Authorized Dealer' to get it
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
3helpful
Honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
Top Kipor Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Jay Finke
Jay Finke
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
