It seems that DMC-FX01 was designed for the old SD card only, which is with limited storage of 2G. For the higher memory, it is then called SDHC, including the 4G memory and higher.
I have surfing panasonic and some other websites, but cannot see any way to solve this through eg. upgrade...
FX-01 was good camera in it's day but it has been out for 12 years and times have changed. That said, you can still get 1GB and 2 GB SD old-style cards on ebay and other sites. By the way, why hunt for a way to shoot on a 4GB+ card anyway? Low resolution (this one is 6mp) digital cameras with high capacity cards is a recipe for disastrous data loss. As long as your original cards for this camera are not corrupt just keep re-using those.
SOURCE: will a SDHC 4G card work inthe c875 camera ?
i don't know if you got my last post (pc playing up,im not going to tell you its the user :))
the answer is no you can only use upto a 2 gig card on this camera
(did a search on the kodak website then phoned them up for you and that's their answere)
SOURCE: I put a 4GB Sandisk SDHC card into my Panasonic
no way to solve...only SD is applicable...4G SDHC is not suitable for it
SOURCE: Using a sdhc card in a Panasonic DMC-FZ10
There is no "new" firmware upgrade for this model. Meaning it is NOT compatible with the SDHC card. Largest you can get is an SD 2GB card.
Sorry
SOURCE: Lumix DMC-FX01 Buttons not working
Remove the card and battery. Clean the battery contacts inside camera with a cotton swab lightly dampened with rubbing alcohol. Be sure battery is charged. Press all buttons on camera. Insert card and then the battery. See if it works. If you can now get into the setup menu, you can do a reset from the menu.
