Question about Sony BRAVIA® DAV-HDX576WF Theater System with Wireless Speakers
I have just installed a Sony Bravia KDL55W905 with a Sony BDV-E3100 3D/Blueray surround system, when playing DVD Surround system works perfectly, but when playing programmes through TV, volume very low and no surround sound.
  • 20 Answers
How have.you connected the TV to the surround unit ?
Posted on Mar 10, 2014
  • scousemumble Mar 10, 2014
SOURCE:
SOURCE: Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Posted on Jun 20, 2008
  • 4 Answers
SOURCE: sony compact AV SYSTEM DAV-S400
Hi Joey - I had exactly the same problem.
In my case, I followed the advice of others and took the thing apart. On the main amp board there is a large brown capacitor. Mine had come completely loose, so I soldered it back in place with a good amount of solder to make sure the contacts were ok. I also dabbed some solder on the headphone connectors on the same board (just follow the wire from the headphone socket to the board). Well, when I put it back together and tried it again everything worked perfectly, and it has so far remained free from the error. Hope that helps !
Posted on Nov 27, 2008
SOURCE: Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Posted on Dec 11, 2008
i just hooked up my sony blue-ray to my samsung suround sound.but i cannot get the sound to work.
Posted on Dec 14, 2008
SOURCE: Sony DVD Home Theater System remote control code
I have the same system and one of my dogs got to the remote. I have a philips PMDVR8/PDVR8 universal remote. I was able to get the dav-hdx265 to turn on/off and do volume up and down by using code 0200. I have not been able to get the DVD functionality to work yet, but I will post if I do.
Hook up new blueray thru old home theater system
Yes you can. If you have more than 1 HDMI sources and your old system only has 1 HDMI in, you may want to invest in an HDMI switch. They are inexpensive (under $20 on Amazon) and let you choose 4 HDMI sources to feed your system. The audio is embedded in HDMI and you may have to select the choices (surround versus stereo) when you play the disc.
Dec 25, 2012 | Sony DAV-DZ175 DVD Home Theater System
Sony BDV-370 DVD/5.1 theater hooked to Sony Bravia TV and cable box. No sound comes from rear or center speakers with HD cable.
Three things can cause this:
1) not all HD is recorded in surround sound. You can very well watch an HD program that just has Left/Right stereo audio. Tombstone on bluray is even only in Dolby 2.0
2) wrong connection is used. If you only use red/white analog stereo cables you will only get sound out of the left/right mains.
3) setting on the cable box is set to stereo and not surround. Changing this varies by cable box manufacturer.
Mar 01, 2011 | Sony BDVE300 Theater System
Does this model have Bravia sync?
Yes it does per SONY web site:
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&productId=8198552921665164630&langId=-1#specifications
BRAVIA® Theatre Sync™ technology
Sony® created BRAVIA® Theatre Sync™ to go beyond basic digital audio and video transmission. Based on the HDMI-CEC function, BRAVIA® Theatre Sync™ will be included on select BRAVIA® Theatre home A/V systems and components. This useful function reduces the hassle and time consuming job of powering up, routing signals, etc. to the simple push of one button.8 Want to play your DVD on your Sony® A/V system? Easy, just push PLAY on the BRAVIA® HDTV remote and everything is taken care of for you. Even when the system is off! Want to change from TV sound to digital surround sound through your Sony BRAVIA® Theatre A/V system? Just one push of the Theater Sound button on the remote and voila, surround sound through your system. Want to power down everything once you've finished enjoying it? Push one button and the TV and A/V system powers down. BRAVIA® Theatre Sync™ helps make things a whole lot easier to operate.
Feb 02, 2011 | Sony BRAVIA KDL-40V3000 Television
Trying to make the sound go to the surround sound
how are you conecting the tv to dvd surround
phono plugs or scart /ero plug? best results are to conect from tv audio out to input on surround i have an older sony and it wont work though the start lead DONT FORGET TO SELECT SOURCE
Mar 04, 2010 | Sony DAV-C770 System
I bought the sony bdv e500w surround sound and hooked up a optical audio to my tv and that is a sony bravia but it will not work with the surround sound when i hook it up using regular audio cords it works...
im having the same problem, except im connected via audio components and hdmi...cant get sound through the speakers when the TV is on, it doesnt make any sense.
Feb 14, 2010 | Sony Audio Players & Recorders
PS3 no longer plays Bluray discs in surround sound
check your blueray settings updates can reset them sometimes.
Apr 23, 2009 | Sony Playstation 3 (PS3) Console
Surround Sound from PS3
Are you getting any sound?
If your marantz amp is part of a home cinema system then depending how old it is will depend on if it will do it automatically.I have just bought a sony surround system and it detects the signal range ie it knows it is being transmitted in 5:1 surround.If you have an old system you may have to do this manually, this should not be diffecult there should be a sound setting.
Jan 28, 2008 | Sony Playstation 3 (PS3) Console
Audio via hdmi
Have you tried to hook up your DVD player directly to the surround sound system? If you direct the sound through the TV, it has to pass several circuits and the quality will be lover. Just connect it right away to your sound system. :-)
May 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA® DAV-HDX576WF Theater System with Wireless Speakers Logo
355 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
