To determine which firmware you can download for your Sansui smart TV model SLED-50FHD, I recommend contacting Sansui customer support or visiting their website. They should be able to provide you with the latest firmware version for your specific model of TV and instructions for downloading and installing it.
Keep in mind that installing firmware updates can be a complex process and may require technical expertise. If you are not comfortable performing the update yourself, it is recommended that you seek the help of a qualified technician.
I hope this information is helpful. If you have any further questions or need additional assistance, don't hesitate to ask.
Hi Melvin, if you can download the firmware to a USB memory, empty it and install it on the TV
You have to find the firmware update, according to the model of your TV
I hope I can solve the problem
Greetings Franco Dosil
Hola Melvin, si puedes descargar el Firmware en una memoria USB, vac?a, e instalarlo en el televisor
Tienes que encontrar la actualizaci?n del Firmware, acorde del modelo de tu televisor
Espero pueda resolver el problema
Saludos Franco Dosil
Go to settings, support, software update. Make sure that your TV is connected to the internet. There may be a check box for automatic updates, check this for future. Then check update version. The pop up which follows will allow your tv to download and update the firmware. You should be able to install Netflix. ( Also in settings, options, make sure your service country setting is set to your cointry to USA
You can re-install the firmware with the latest one suited to your TV. But before doing that, contact the authorized service center, and make sure about the version of firmware that should be upgraded with your TV model. They will provide you proper assistance. Gopakumar Gopalan Google
Never do any more adjustments or experiments with present condition. It might make it irreparable.
Usually the firmware is installed by your provider. You cannot physically install TV Box firmware because it is a product of the company that manufactured the device. The box must be taken to your service provider for you to update or flash the Bios.
