Have an LG LDF6810ST dishwasher bought in 2006. When starting any cycle, ends when the water fills the bottom of the machine and beeps an error code "FE Error". The drain pump seems to work because I can "cancel" a cycle and the water drains out. I suspect the step after the water fills bottom tub, is the heating cycle or some other cycle that cannot start because of a faulty part. Has anyone experienced this and know what the fix is? I'm mechanically and electrically incline and need some guidance on this repair if possible.
SOURCE: LG LDF6810 Dishwasher Starts filling with water then pumps water
Because you are not getting an error message, I agree that the controller card is malfunctioning. Almost everthing else would triger an error.
Recommend replacing the controller card.
SOURCE: LG LDF6810ST dishwasher
Steps to fix OE are as follows:
-Check the Drain Hose is not kinked or blocked.
-Are all wiring connections OK?
-The drain outlet of sump is blocked.
-The Drain Pump/Motor or circuit has failed.
To check the pump motor:
-Measure the electric resistance of Drain Motor. (best between 20-40 ohms)
If out of range, replace the Drain Motor or repair the Circuit.
Good Luck! Please report back your findings.
SOURCE: IE error on LDF6810ST, it's not the valve or the controller
Try to check water flow sensor that attached to the water intake plastic thin container. It's located from the inner side therefore you won't see it from the first glance. You have to take it apart then find it from the inner bottom side.
SOURCE: my lg dishwasher does not
E1 means a leak has been detected . Check hose connections .Or drain hose height.1E would be water pressure issue.See service manual
LDS5811_Service_Manual.pdf (application/pdf Object)
Was this helpful?
SOURCE: water leaking from bottom of door-LG LDF6810ST
Hello, cindy
I was trying to help
you out here. I was going back to some customers that asked questions
in the past and it appeared that no one answered them, so I thought I
would take some of my personal time to see if I can help. Even though
this site may not have your exact model or brand, This link will help
you tons. Here is a link
to about everything you want to know about your dishwasher, from repair
to trouble shooting it,pictures, video's. Just scroll around and you
will see tons of information to almost any question you might have on
your dishwasher. If you go to this link and click around, I am sure you
will find out so much about your dishwasher, you will know more that the
company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time
to rate my help and some kind words written would be appreciated for my
free help , I would appreciate it. Here is also my direct link to my own
pages of other areas of my expertise for other problems you might have
in Automotive,Appliance, and Electronics. Drop In anytime for my help.
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Could you post the first three digits of the serial number?
