Televison & Video Logo
M
Michael Ward Posted on Mar 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The menu options keep poping up
After turn on my tv it works perfct for about ten minutes and then the menu options will come on the screen for a few seconds then go off for a few seconds then menu options pop back up again and it does this for aprox. 30 to 45 minutes and then the tv works normally. But if you turn it off and then back on again the whole process starts over again. The tv is less than one year old and is a SEIKI model number LE-55GD2.
ifawnmeade
Level 2:
Sergeant:
Champion:
  • Expert 266 Answers
  • Posted on Mar 09, 2014
ifawnmeade
Expert
Level 2:
Sergeant:
Champion:
Answers
266
Questions
Helped
58310
Points
661
I doubt this is a user fix. There is a problem in a mother board .
I would run to the warranty and try to replace it.
5 Related Answers
A
Anonymous
  • Posted on Sep 03, 2007
SOURCE: Menu options keeps popping up
You need a software upgrade. It is free. Go to Philips.com and enter your model. You will find the software upgrade info there. You need a USB memory stick. Easy to follow instructions are at the website. Another issue with these is the cable from the IR rec is dressed too close to some large coils on the X board. The cables need to be rerouted.
Anonymous
  • Posted on Feb 04, 2008
SOURCE: tv freezes, goes black, starts again
I had a similar problem, mine was a bad earth connection on the main (tv input) board. it earths through the screw mountings so check they are screwed in nice and tight, probably best to remove and then refit it.
Anonymous
  • Posted on May 26, 2008
SOURCE: Keeps turning off
I am having the same problem, is there any solution for this problem?
Anonymous
  • 3 Answers
  • Posted on Jan 11, 2009
SOURCE: MY AKAI LCT3201AD TURNS OFF BY ITSELF
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Anonymous
  • 304 Answers
  • Posted on Jul 17, 2009
SOURCE: Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Why does the menu and channel display keeping poping up while watching tv?
1. Remove the batteries from your remote to ensure that is not sending signals to the TV.
2. The TV may have an internal problem and might need repair.
2helpful
2answers
My LG T.V's Menu keeps popping up and wont go away, when i try to exit off it, it just pops back up, sometimes it doesnt go away the after a few minutes it does then comes back, I dont have any extra...
The tv manual control buttons board like POWER,MENU,INPUTS,CHANNELS - +,VOLUME - + could be bad and causing this problems.Take the tv aparts,unplug the connection that plug of the mamual pc board functions,the tv will work as normal only no manual buttons functions,if the Menu screen stop poping up,than u know the manual control buttons board is bad must be replace.If Menu it still poping up,than u have a bigger problems,the tv Tuner signal board is the cause and the problems.That the board,that take in the incomming broadcasting cable wire is the problems.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes boards like the manual control buttons board or the tv Tuner signal board.
1helpful
2answers
I doo not have the origanal control for my philips tv... I have a dish universal remote!!! And it does not give me the option for cc off!!! Help me plz its driving me crazy
That is a problem, the original remote is needed for all options, you could go to the nearest TV repair shop to see if they might have good used one for your model. Some tv tech's keep a large box of remotes for that purpose. The only other option is contact the company for a new remote if they are still available.
Have just bought a panasonic tv and every ten minutes an information notice comes on the screen about hdmi info etc how can I get rid of this?
Go into ur tv menu.Goto OPTION.Go down to Program Display Title.Pick option No.Will have no more Info..ect. display anymore.
1helpful
The tv will not let me channel search keeps telling me to unlock threw service menu. tv will not work on antenna a or b and when im using the dvd threw one of the imports after five to ten minutes the tv...
Your tv is tuning locked. Go to menu and get the tuning lock function by pressing PR+,PR- keys. Reach to the tuning menu by the help of Vol+, Vol- keys. Select the tuning lock fumction, and turn it to 'off' .
1helpful
The menu keeps poping off and on
The cuircit board that contains the front buttons is at fault. you have two options remove the front button panel and use remote only or replace this cuircit
1helpful
Black box keeps poping up in the middle of the tv
your closed captions are turned on and in the text mode. turn them off or select cc1 to view that captions
2answers
KEEPS POPING UP GUIDE PLUS MENU
try to change all the micro switch button on the pcb board
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
