Mitsubishi Diamond WD-65831 65" Projection HDTV Logo
Posted on Mar 09, 2014
Tv shuts off after 5 to 10 minutes on its own
2answers
My Toshiba DLP Projection TV model number 44NHM84 will turn on but shuts off after 1-2 minutes. What do I need to do to fix this issue?
There are several reasons why your Toshiba DLP projection TV might be turning off after a few minutes. Here are some steps you can take to try and diagnose and fix the issue:
  1. Check the lamp: The most common reason for a DLP TV to shut off after a few minutes is a faulty lamp. Check the lamp to see if it's still functioning properly. If it appears to be damaged or has reached the end of its life (typically around 2000-3000 hours), replace it with a new one.
  2. Check for overheating: Overheating can also cause the TV to shut off. Check the fan to see if it's running properly and clean any dust or debris that may be blocking the airflow.
  3. Check for firmware updates: If the TV's firmware is outdated, it can cause it to shut off. Check the manufacturer's website for any available firmware updates and install them if necessary.
  4. Check the power supply: A faulty power supply can also cause the TV to shut off. Check the power supply unit to see if it's functioning properly and replace it if necessary.
  5. Check the color wheel: If the color wheel is damaged or not functioning properly, it can cause the TV to shut off. Check the color wheel for any damage or signs of wear and replace it if necessary.
If none of these steps solve the issue, it may be necessary to have a professional technician diagnose and repair the TV.
1helpful
Fridigdere up rite stackable dryer keeps beeping and shuts off after running for about 5,10 seconds,what do I check,?????
Google the model and codes. You should find instructions in how to to retrieve the codes and that will point you in the right direction.
Oct 14, 2016 • Dryers
Tv works fine,cut it off and it will not come back on . Red light blinks 6 times, then repeats itself.
this is an indication of a overcurrent/ overvoltage error....meaning short in a voltage supply. I have seen this problem in the shop with this set. IN MY CASE it was shorted convergence chips. but it could also be any of the low voltage supplies 5,10 15,-15 lines
2answers
Mx4000 128mb on xpsp3 problem
in windows power settings, you ajust the time the monitor runs and shuts down one setting is do you want the monitor to stop after 5,10 or so mins you answer never that will cure the shut down
Tv shut off on its own
Replaing the lamp will fix this problem most of the time.If not count the blinks. This is an error code.
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
TV shuts off after 5 minutes.
ours did that we had to replace the lamp
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
