Kenneth Cole KC3500 Wrist Watch Logo
A
Anonymous Posted on Mar 09, 2014
Kc9110 touch screen - Kenneth Cole KC3500 Wrist Watch
I can't get the analog time on kennth Cole kc9110 watch after changing battery the digital part in running fine please help thank you
With this type of dual display watch, the two 'mechanisms' are often independant with their own batteries. It's quite possible that the battery for the analogue display has been missed - often they are underneath the battery for the digital display with an insulating cover to isolate the batteries from each other. Sometimes it's even necessary to remove the digital module to get to the analogue module. Obviously, you would need some experience of dismantling watches (and to be very careful) to sort this out. If you don't feel confident, and you value the watch, take it to a professional.
Jul 11, 2015 • Watches
Can't unlock the touch screen to set KC1850
I'm having the same problem. Has anyone figured it out - how to unlock the screen.
N.B. It worked previously, then stopped.
1helpful
Kc9110
not able to know where is the button to adjust digital time n date
24helpful
3answers
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 • Watches
2helpful
Did you notice that this is TOUCH SCREEN? This is why you have just one resetting button. All the settings must be done using TOUCH SCREEN. So, Tap on appropriate icons on the screen and play with them till you find the right settings.
Unfortunately there is no instruction downloads available on the net, so, you have to find the way around yourself.
Rate me, please.
Mar 21, 2009 • Watches
Top Kenneth Cole Watches Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
