Cant Alter main Commercial Message , also tried via hooking laptop into it and even with the drivers cant find it. Manual stupid
Ok. So go inside the Menu.
- Press Enter or 1, it should select Messages
- Press Enter or 1, it should select Commercial Messages, and display the first line of the previous message.
- Press Enter and type the first line of your commercial message.
- Validate with Enter, and then (Enter again ?) or just start typing the second line.
- Validate with (double ?) Enter, then type the third line.
- Validate with (double ?) Enter. A long receipt should be printed display should return to Main Menu screen.
SOURCE: I have a TE-2000 cash register and find the
Turn your key to PGM
enter 2 subtotal
enter 0132 and press subtotal
now you enter your 21 or 24 characters for the first line and press CA or the lower right hand button.
Now enter 0232 and press subtotal and again enter characters and press CA or the lower right hand button.
Follow this for 4 lines and when all done press Subtotal.
I believe the register you have will show you the characters on the keyboard and just use those to make your logo.
Turn the commercial message on. It is an option as it wastes paper if you don't need it. Check the codes in machine features programming. The codes will depend upon the other settings you need within that that set of features. this is explained in the manual.
If you don't have the codes, they are in the manual here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-C2000_users_and_programming_manual.html
