Lexmark X4550 InkJet Printer Logo
A
Anonymous Posted on Mar 08, 2014
Reset lexmark 23 black cartidge - Lexmark X4550 InkJet Printer
1 Related Answer
Anonymous
  • 20 Answers
  • Posted on Jun 17, 2010
SOURCE: Lexmark 3600-4600 printer.message says
defective cartdge , replace it
Why does my lexmark C748de have no black, only cyan, magenta and yellow on prints?
Check to make sure that the black cartidge has enough black toner level, ie not empty.
Lexmark p4350 not recognising colour cartridge
Have you purchased like for like. Some, there is a chip that has to be reset if cartidge is a refil?
If still available reinsert old used cartidge and see if you receive same message or just the empty/renew.
Happens with HP too.
I am trying to install a new black ink cartridge #23 and it keep giving me an error message saying left cartidge is installed wrong. I have replaced these cartidges many times and never had this problem.
you may not have it seated properly just take it completely back out and reinstall it and it should work fine if not unplug it and try again
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
4helpful
I have installed a black 23 print cartridge in my x3550 printer, and it is indicating that the cartridge is incorrect, however, this is the same cartridge that is required.
Left/Right Cartidge Incorrect - huh? The printer is saying Left Cartridge Incorrect or Right Cartridge Incorrect,
and you are sure that you inserted the correct cartridge, a #23 or #24.
A small number of #23/#24 cartridges will report as Incorrect Cartridge because
of a manufacturing issue. There is a firmware upgrade available to fix this problem, and allow
the printer to accept the cartridge.
3500-4500 Series (X3550, X4550)
3400 Series (X3430)
1400 Series (Z1420)
To apply the upgrade:
  1. Make sure the printer is turned ON and connected with a USB cable.
  2. Download and run the appropriate update program using the links above.
  3. Be careful not to disconnect or turn off your printer while it is being updated.
When the update is complete the printer should automatically restart and accept the #23/#24 cartridges.
Refill instructions for lexmark 23 & 24
You will have to buy a new one because the return program cartidges are not reuseable. I read somewhere that the usage is connected to the cartridge, so even if you exchange one with a friend, theirs will not work on yours. Not sure how this works, but I had one and could not figure out how to bypass this feature. Best solution I found was to buy a new printer. It was cheaper than buying new cartridges.
Printer won't recognize new ink cartidge
Most common problems like this come from non-genuine cartridges, or refilled ones.
Problem with X2250
Lexmark cartridge's have a flaw in them from the mexico manufactures. The cartidge works ok on printer for a wile then quits working after sitting for to long. I work for a large firm that repairs coppiers and printers and we find this to be a problem in many of the returns. Clean connections and then reset printer by unpluging it.
If this does not solve problem you have a bad carriage.
By Disaac Ohio
1helpful
2answers
After refilling cartidge it still says it is empty
IB4G2008: Do u actually have a solution or a better driver for this printer OR are u just out to promote your site?
Your solution is not helping & if u think it is, pls oh pls,let me know of a DIRECT link for it, as i havent found anything that makes the problem better, nor a better driver for that particular printer.
Pls advise.
eldiablo2008
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
