I purchased a laguna double 6 drawer black from Walmart and the above mentioned items are not in box 1 or 2. Need them ASAP
SOURCE: broken antenna
It is not Very Easy to get to But, You can access this through the Fender Holes under the Hood. Please Rate My Response! Thanks!
SOURCE: Missing Power Cord, Stand Base, Owner's Manual for Element 15" TV
The manfacturer has information for you about this model when purchased from Circuit City: http://www.elementelectronics.com/support2.html
The distributor Element uses provides parts at http://www.encompassparts.com/
(you may have to have a legitimate repair center login in and get parts from them)
SOURCE: Need instructions!
Any Chance you could send me a copy of the instructions. I need to convert the crib and do not have the instructions.
Thanks so much.
[email protected]
SOURCE: Unique Oak Treasures Crib - Full Bed Bassett Model 5542-0521
We have this crib as well. We bought it from Babys R' Us in 2005.
We also purchased the rails to convert it to a full sized bed. It did not come with instructions but I can explain to you how to put it together.
The rail conversion set should come with 2 pieces of wood that act as the bed frame. You do not need to purchase the extended frame. The set should also come with 4 long screws, the hex tool to tighten it and 4 metal pieces. You might also have some wood nail cover plugs.
Once you've taken apart your crib, the only pieces that you will need are the 2 longer pieces of the crib...the headboard and the footboard. The 2 shorter side pieces which served as a headboard and footboard as a crib and the metal grate to hold up the mattress can be put into storage.
On the sides of each of the new wood rails, you will see a circle indent on each end with a hole. You will insert one of the long screws into each and then insert it into the head board. You must use the special tool to screw/ tighten it in. The metal flat pieces can be inserted into it the circle befor eyou are done tightning so that it does not strip or damage the end of the circle. You do this with the other rail on the other end and then add the footboard using the same process. If you would like, I can send you a copy of what this looks like close up. ( the cricle indent with screws. The bed is extremely strong. We've all napt in it as a family along with our 2 large dogs. I highly recommend ordering the extra long/ tall bed rails from OneStepAhead for security because my son has rolled out of the bed and it is super tall!
http://www.onestepahead.com/catalog/product.jsp?productId=534602&parentCategoryId=85183&categoryId=85216&subCategoryId=86203
SOURCE: I need instructions for the child's pink singer
Hey, I just bought one new and sealed from Joanne's and it's missing the booklet and any instructions, too! I'm online looking...I went to the www.NKOK.com website and sent them an email requesting one.
