Question about HEWLETT-PACKARD photosmart C5250 All-In-One InkJet Printer
The printer takes a long time to print.
Slow, sluggish, printing
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Buy a faster printer.
And, no, I'm not being a smart-aleck
HP rates this printer at up to 32 pages per minute -- in fast draft mode black ink only... But even their ratings show it takes over a minute per page when doing quality printing in color.
And those speed ratings are all "after first page" -- ALL printers take longer for the first page due to the time it takes for the computer to set up the page and process the information.
As the specs suggest, you can get faster printing in black-only instead of color and by choosing fast draft mode instead of quality or normal mode.
There is very little that could be wrong with the printer that would make it print slower than usual -- generally any problem would make it not print at all or cause it to print incorrectly. Generally speaking whatever speed you see is simply the speed of the printer itself based on the settings you have selected, the software you are using, and the speed of your computer.
You can refer to the information on the HP website. It is just possible that replacing the printer driver MIGHT help but other than that there simply isn't much you can do about the speed of this (or any) printer unless you want to choose a lower quality print setting.
HP Photosmart C5250 All in One Printer Product Information
Posted on Sep 13, 2016
SOURCE:
WHAT CAN I DO TO MY PRINTER TO MAKE IT PRINT FASTER?
Depends on what part of printing that's slow. Parallel port may be slower than a USB or network connection. If your printer doesn't include a USB port, one may be available to add to it. Same for a network connection.
Other things that make laser printers slow is what you are printing. Text typically prints quickly, but images take longer, and large images take even more time.
Some software waits to send the first page until the last page is done "processing" before sending anything to the printer. You may be able to change that.
Nov 09, 2015 | HP LaserJet 2300 Printer
Slow printing
Check that the default setting for print quality on your printer driver hasn't been set to "Fine".
In your Opertaing System, find your printer (in XP it's under Control Panel / Printers and Faxes) and select Properties. This should then bring up the settings for the driver.
Fine printing quality takes over double the time "Normal" quality takes so would considerably slow your printing.
Apr 10, 2014 | Brother MFC 210C All-In-One InkJet Printer
Problem: it's extremely slow on HP Inkjet 2660 printer.
Changed the electrical core, and problem resolved per HP support.
JT
Jan 05, 2010 | HP Color LaserJet 2600n Printer
Printing is really slow almost 10 mins to print i am using Vista and have had updated the driver for vista but still
Epson R230 print slow at PHOTO, very slow at BEST PHOTO, if you do not need photo quality prints try printng at TEXT AND IMAGE for faster printing and the quality is still good. Also try to lower the resolution of that you are about to print, high the resoluton images takes longer time to print. Hope this will help you, Good luck!
Oct 14, 2009 | Epson STYLUS R230 InkJet Photo Printer
Printing is very slow
Try adjusting your printer settings to a lower quality. That will usually speed things up.
I hope this helps :)
Best Regards,
James Trageser
Jul 29, 2009 | HP LaserJet 5550dtn Printer
DELL 1720 PRINTER PRINTS VERY SLOWLY.
Whenever I have a customer tell me their printer seems to be running slower, 9 times out of 10 its what they're trying to print...not the printer. Heres a couple of things to do and ask yourself. First I'd do a test print from the printer itself. Does it kick it right out? Then go to the printer folder on the computer, right click on the printer, go to properties..click print test page. Does that come out pretty quick? Okay if they seem relatively fast then its beginning to look like something other than the printer. Try printing the job that seems to run slow. Then try printing from a different program. Is there a difference in speed? The job that prints slow may have graphics or require more memory then it use to. Perhaps you changed the graphics content on the page and the printerr is taking more time to process it. Adding more memory to the printer can help that.
Did you make any software change to the printer about the same time you noticed the slow down?
Have you changed the font color in the computer to something other than black for that particular print job? I've seen monochrome (black and white) laser printers slow down because its trying to convert the job to say violet or some other color. Its a black text printer and apparently printing color confuses it ..lol My bet is..if you really sit down and think back...something changed in the content of what your printing thats taking it longer to process it. Hope this helps!
Jul 10, 2009 | Dell Office Equipment & Supplies
SLOW, SLOW PRINTING
try saving the things you want to print as a pdf file, then print them from there
Jun 01, 2009 | HP DeskJet 3550 InkJet Printer
Very slow printing
printer hp laserjet 1020 its working when giving first page to print but after gives second page its take time
Apr 02, 2009 | HP Office Equipment & Supplies
Allegro2 Print Too Slow (25 seconds send from Windows XP)
miaharoon: Printing via Windows driver it's too long time because the driver sent a lot data to printer. Also the print speed via serial port it's slow. Inside driver, install Datamax printer fonts and barcode fonts to use it in Windows programs.
Roberto Martinez
padrino99@prodigy.net.mx
Jul 22, 2008 | Datamax Allegro2 Thermal Label Printer
HEWLETT-PACKARD photosmart C5250 All-In-One InkJet Printer Logo
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Harrie
Daniel
Daniel
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
