Question about Razor E300 Scooter
ALSO IF ANYONE HAS ANY TROUBLE WITH RAZOR SCOOTERS WITH GETTING THEM TO GO,IT CAN BE THE TENSIONER,WHEELS,CHAIN,MOTOR,BATTERY,CHARGER,CONTROL MODULE,RESET BUTTON,LIGHT SWITCH,AND THROTTLE.IF IT WORKS,BUT WON'T RUN GREAT,IT CAN BE THE BATTERY,MOTOR,CONTROL MODULE,LIGHT SWITCH,RESET BUTTON,AND TIRE TYPE STUFF.. :) Hope this helps.If anyone gets on with trouble,ask me and I will try to help.
    Habit-Forming:
    Scholar:
  • 89 Answers
I purchased my batteries on E-bay. Selected the highest rated with a Square trader warranty. Delivery time was 4 days, new was was going to ask.
Delivered to my house for$21.00 with both batteries, charged and ran perfectly. Extended Warranty was also offered but declined.
Batteries still working great 6-months latter.
Posted on Dec 05, 2014
  • Razor Master
  • 2,478 Answers
Sould be turning throttle handle. Is your battery charged?
Posted on Mar 08, 2014
Testimonial: "Yes the battery is charged.The upg batteries I got should work.They are sold specifically for the electric scooter.I believe maybe the batteries may be some cheap built ones,or may be the wrong kind.Thanks for your help :)"
  • Dennis Key
    Dennis Key Mar 10, 2014
    Your batteries should be 12v 9ah
4 Suggested Answers
SOURCE:
  • 5 Answers
SOURCE: When I plug in the charger is shows green, but the
Check the voltage output of the charger. It should be about 28 volts. Most likely your batteries are dead (over 2 years old?)
Posted on Apr 11, 2010
  • 38 Answers
SOURCE: have an e100 razor electric scooter. it has not
The batteries are dead. The battery in these scooter need to be kept charged or if not in use for a long time charged every 3months. Otherwise, like what to you, they will go dead. The chemicals in the battery have deteriorated to the point where it won't hold a charge. Replacement batteies are available at:
razor.com
Posted on Aug 18, 2010
SOURCE: Razor E100 reset button and no charge
Hi... My son hasnt used his Razor E100 for nearly a year as couldnt find the charger.. I finally found it and as soon as I plugged it in the plug was showing green light as that it was fully charged... When we turn the unit on it lights up but its dead... Where can I get the cheapest battery (and does it have 1 or 2)? Or you mention a reset button? Many Thanks...
Posted on Jan 25, 2013
Scooter is saying error code 8 which is motor does anyone know what this could be please?
Pride Mobility Products Victory 9 Scooter 4 Wheel Error code
www.fixya.com > ... > Pride Mobility Products Victory 9 Scooter 4 Wheel
Pride Mobility Products Victory 9 Scooter 4 Wheel, error code related issues. ... Question about Thermometer Mobility Scooters ... error code is 8 Error code 8 means an internal controller error or problem and requires replacement of the controller. ... Theysay there is no listing for code 9 I have replaced the batteries,checked .
Basic Troubleshooting Instructions - Pride Mobility Productswww.pridemobility.com > Resource CenterPride MobilityScooters. INFINFB2040 Sonic Troubleshooting ... Chargers. INFINFB2586 Charger Indicator Codes ... Disclosure Statement Pursuant to Cal. Civ. Code 1714.43(a)[PDF]Legend Owner's Manual - Pride Mobility Products
Nov 28, 2015 | Pride Health & Beauty
Tip
How to extend the battery life of Razor Scooter Batteries
You can extend the life of your scooter's battery if you take proper care of it. Most people report trouble in getting more than a year or two out of their razor scooter battery set. This is actually a common problem with vehicle batteries.
  • Keep your battery charged
It is recommended to keep your battery fully charged to avoid the build-up of sulfate-ion inside it. Sulfate-ion accumulates when the battery is in a discharged state for a long time.This is the most common reason of premature depletion of lead acid batteries. This can be easily avoided if the scooter battery is kept in a constantly charged state.
  • Charge you Razor Scooter Battery during the Off-Season
Even if not used Sealed Lead Acid Batteries will self discharge over long periods. This will leave the battery in a not fully charges state which will enable the sulfate-ions to build up inside the internal plates which will slowly deplete the battery's capacity. In order to prevent that, you should charge the razor scooter battery at least once every three months when it is not in service.
  • Use a Battery Tender
Battery Tender chargers are a great way extend the life of your SLA batteries as they are designed to fully charge and maintain a battery at proper storage voltage without the damaging effects caused by trickle chargers.
References:
Battery Maintenance 101 How to Extend Battery Life of Razor Scooter...
BU 804b Sulfation and How to Prevent it
Deltran Battery Tender
on Jun 19, 2015 | Razor E100 Electric Scooter
My e300 razor run but will not move
Check to see if the chain is moving when you apply throttle. If the chain is not moving but you can hear the motor working then it is likely the chain has come off the motor sprocket. If this is the case then follow the steps in the user manual to refit the chain and adjust the tension.
Aug 12, 2014 | Razor E300 Scooter
Chain keeps poppin off
These are the instructions for adjusting the chain. They are taken directly from the manual available at http://ep.yimg.com/ty/cdn/razorama/e100e200e300manual.pdf
To adjust the chain:
1. Loosen the axle
2. Loosen the brake anchor (this is attached with the small bolt in the long slot on the left side of the rear fork)
3. Tighten the tension adjusters on the axle 1/8 to 1/4 turn to tension the chain. Tighten both adjusters the exact same amount to maintain the wheel alignment.
Note: this system of adjusters is common to motorcycles and BMX
bicycles so I your are not familiar with it, if you know anyone who is,
they would not have a problem adjusting it for you.
Chain tension: The chain should be "just not-quite snug" in other
words, not taut or sloppy loose. BE CAREFUL NOT TO ADJUST TOO TIGHT. The tensioning system can easily impart too much tension and snap the chain or bend the motor output shaft. Turn the adjusters 1/8 to 1/4 turn at a time and recheck the tension each time.
4. Once the tension is good, tighten the axle and brake anchor bolt. Test run the scooter. Readjust as needed.
Jan 02, 2014 | Razor E100 Electric Scooter
Razor Bella scooter problem
yes sounds like the control module, you can always jump the batteries directly to the motor to make sure that the motor is ok
Jun 25, 2012 | Razor USA Razor Pocket Mod Electric...
Razor e200 scooter the chain tensioner spring - where does it attach?
tensioner should fit on axle or behind the axle on the edge of thew fork where hardware should be mounted to adjust tensioner
Jun 10, 2012 | Razor E200/300 Electric Scooter Battery
How do you get the tyre of the rear wheel off a razor 300
Its not meant to be removed. Purchase a new one and save yourself some troubles. You need special tools to remove it. I highly recommend purchasing the wheel complete.
Sep 12, 2010 | Razor E300 Scooter
My sons razor e200 dies quickly. I have changed the batteries, brought a new charger. I have checked the connectors and the tires are not flat The light is green but after 25 yds, turns and says needs to...
Problem is not the batteries then. Replace the controller. The controller could be resisting some of the charging current to the battery.
But first try this:
Charger the scooter with it OFF
Directly connect the charger to the battery
If still the same problem then:
Directly connect the charger to the battery then,
connect the motor leads directly to the battery and see how long it runs. It with new the batteries it should run longer than a minute. If it does than something is definitively wrong with the controller.
Aug 15, 2010 | Razor E200/300 Electric Scooter Battery
How can I put chain back on my E200 razor electric scooter?Everything is in the way.
First your going to remove the deck.
Take off the chain tensioner
Next remove the motor and put the chain around the gear
Put the motor back on the scooter with the chain on
Then take the rear wheel off and put the chain into the gear.
Put the rear wheel back on along with the chain tensioner and deck
Your done!
Note: the reason why I say you have the remove the motor and wheel is the get the chain on. So you may only have to partial remove the motor or tires to get the chain on.
Apr 24, 2010 | Razor E200/300 Electric Scooter Battery
Razor Electirc Scooter, the chain keeps falling off, I cannot see how to tighten it....help
If the chain is too long than shorten it by using a chain breaker. Or you don't have a chain breaker take the scooter to a bike or more preferable a electric scooter shop and have them do it. The problem could also be your chain tensioner check to see if it's tightening the chain.
Dec 17, 2009 | Razor E100 Electric Scooter
Razor E300 Scooter Logo
540 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
