The other E10 fault is a clogged drain pump. Instructions to clean and free this are in the user manual obtained here. http://www.aeg.co.uk/Support/Manuals/
Peter Kay
SOURCE: washing machine not filling
Check the screens at the point where your water hoses connect to the washer. These often get clogged with calcium. A simple vinegar soak or cleaning with a brush will often solve this problem
1. Turn off the water supply at the valve
2 Place a towel or bucket behind the washing machine to catch remaining water coming from the removed hose
3. See if the screen (often cone shaped) is inside the washer side or the hose itself.
Remove the screen, clean it, and replace.
I hope this works.
Hi Gwen Taylor, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? is this hot/cold water or both
