PX 410r uses IDES 4.0 downloadable from
http://www.casio-europe.com/euro/emi/specials/ides/downloads/
and not another version.
I suggest you uninstall the Casio USB driver from Control Panel'system'device manager then Reboot the PC without the USB cable.
Download latest USB driver from :-
http://support.casio.com/en/support/download.php?cid=008&pid=20
64 or 32 bits versions are both available.
Load driver first. Plug in the usb cable only when software tells you to do so.
Uninstall Data manager if wrong version.
Install IDES 4.0
SOURCE: Casio Privia PX-120 cannot be connected to Reason or FL
When you are using midi the sounds from your keyboard aren't sent anywhere. What happens is control messages are sent over the midi cable from midi out to midi in on the other device which must have midi sounds on it (in your case the sound card) to make any sounds. The messages can be things like note on/of or pitch bend etc. If you want to send messages to produce a result on your laptop and still here something you can loop the messages by running from midi out on the device end ( your laptop) back to midi in on your keyboard. A much better explanation is available here:http://www.indiana.edu/~emusic/etext/MIDI/chapter3_MIDI.shtml I also signed up to this site (its free) that has great people and lots of info:http://www.recordingreview.com/ I recommend downloading Killer Home Recording setting up which at this time is also free and has the best advice you could want in it. I'd also recommend checking out Reaper which is comparable to Reason, Cubase or Protools. If this helps please let me know.
