Kocaso M766 Dual Core 1.5Ghz Dual Camera Android 4.2 Capacitive Tablet PC Black Logo
A
Anonymous Posted on Mar 08, 2014
Touch screen is not working properly
The caliber on the touch screen is off I cant touch on anything.
stephen Adams
Level 3:
  • Kocaso Master 2,219 Answers
  • Posted on Feb 22, 2015
stephen Adams
Kocaso Master
Level 3:
Answers
2219
Questions
0
Helped
355078
Points
22262
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
This should reset the calibrations to default.
http://www.kocaso.com/troubleshooting.html
Tablet will power up but has no touch screen
Defective digitizer (a thin layer of invisible material placed just below the glass that senses the figure) in most touch screen devices.
Five things you should know before trying to fix smartphone or tablet...
I dropped it and although the screen isn't physically broken, it's not working properly.
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - Is your Android Touch Screen not working or being unresponsive? ...This will wipe your phone/tablet and return it to its original condition. ... a replacement for a glass broken? will I not reboot my phone and then it will work? .... My zenfone5 was dropped into water and some part of the screen isn't working.
iPhone Screen Not Responding - how to fix? - Tech-addict
www.the-tech-addict.com/iphone-touch-screen-not-working/
Nov 22, 2015 - Although the touch screen problem doesn't occur that easy, but still one can come ... Steps to fix if your iPhone Touch Screen not working properly ... to perform a factory reset i.e. restore your iPhone to its original factory settings. ... Touchscreen devices like iPhone, iPad, Tablets etc. are not only quite costly ...
Dropped phone, screen doesn't work. What repair kit do I need ...
forums.androidcentral.com > ... > Samsung Galaxy S3 > Sprint Galaxy S3
Sep 11, 2013 - When I try the unlock pattern on teh touch screen it does not work. ...the glass there does appear to be a spot that isn't the glass that is physically broken.... And I'm pretty sure once you get the phone disassembled, its just plug and ....Although I only had to do 1/3 of what was in them, they really are great for ...
How do I get my pictures off my phone if I have a broke screen ...
Mar 10, 2014
Brand new Galaxy S4 "broken" for no reason.
Aug 12, 2013
Does the digitizer break when screen is cracked on the Nexus 7 ...
Aug 3, 2013
TF700T now won't turn on.
Oct 15, 2012
More results from forums.androidcentral.com
1helpful
My tablet 7.85 touch screen not responding.cant switch on or off or reboot.Only 5 days old.
It is not the normal behaviour of a new tablet. Don't mess with it. Your tablet is on warranty. Look up where you should take it for a checkup and repair service
2answers
My daughters pink vtech innotab 3s touch screen seems to be not working, she cant touch anything
Try recharging the batteries, or try using another powersource. if this does not resolve the issue then you may need to call their hotline
Supersonic 7" Touch screen MID tablet was dropped now touch sensor not working
This may or may not be fixable without replacment parts. The hopeful solution would be to open the tablet and take a look at the ribbon cable for the digitizer to see if it was moved. Check all the cables to make sure they aren't damaged, and are seated properly. You can get parts online such as ebay if you suspect a damaged touch screen. I think these are around $25-$30.
Need tablet repair help?
http://forum.wasatchtechies.com/
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
7 INCH RCA TABLET SCREEN TURNED DOWN CANT SEE ANYTHING TO BRIGHTEN
Hello I have Rica table. It turns on and everything but i can't see anything it has sound I can still touch the screen but I can't see anything when I touch it pleasenhelp
1helpful
Touch screen and digital finger scan's not working
there is one option that you have tak back-up your data then run recovery disk that is only solution becoz touch screen and finger print software is realy delicate things dont try to paly with if don't have to downlod drivers from the HP site
Top Kocaso Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
