Reset your router using the red reset button in back of the router. Let everything startup and test it. If the problem persists, then you might have to call your ISP or replace the router itself.
Try downloading latest video drivers and Inmatrix Zoom player. It comes with an auto downloader for video codecs. Also try VLC Media Player and Media Player Classic. If all else fails, try Analog-X cache booster.
If you have the original Install CDs that came with the iBook put in
Install Disk 1. When the Menu Bar appears go to Disk Utility (under file manu). Choose your HD and look for
the S.M.A.R.T. status. It should be Verified. Then choose Repair
Permissions. After that is done choose Repair Disk.
If none of this works find the Hardware Test Disk and run that.
You got a bad seal for sure. Even though it looks like a good seal. Open up the lid and see if you got any little bubbles floating up from around the seal or listen for a slow water drain around the seal. Go to Lowes and tell them you need a Korky flapper. Their the best thing since sliced bread and peanut butter.
Your antitheft system is shutting it down. You need to reprogram it. First hook up a battery charger. Then turn the key on. The security light should blink on and off. Leave the key on for 10 minutes. At the end of ten minutes, the security light will stop blinking. When it does turn the key off for five seconds. Then turn the key on. Repeat the 10minutes. Turn the key off then on. Repeat the 10 minutes a third time. At the end of the 3rd ten minute period , start the truck. It should be reprogrammed and continue to run.
