Pramac P6000 6000w Super Silent Enclosed W/ Yanmar Engine Diesel Logo
A
Anonymous Posted on Mar 07, 2014
Pramac p6000s alternator - Pramac P6000 6000w Super Silent Enclosed W/ Yanmar Engine Diesel
Pramac Generator. How do I fixed alarm off blink slow alarms on blink fast stop phases, for my Pramac Generator.
Question edited for clarity, correct spelling of 'phases' AGAIN. I remember you from yesterday!
Question moved from Cars and Trucks category. They have 30 models or more.
Blink codes.
https://www.google.com/search?q=pramac+generator+alarm+list
Pramac generator no power
Based on the information provided, it seems that the generator is producing voltage but not delivering it to the connected devices. Here are a few troubleshooting steps you can try:
  1. Check the circuit breakers: Make sure the circuit breakers on the generator are not tripped. If they are, reset them and try again.
  2. Check the connections: Ensure that all the connections between the generator and the devices you are trying to power are secure and not loose.
  3. Check the voltage regulator: The voltage regulator controls the output voltage of the generator. If it is faulty, it may not be allowing voltage to pass through to the connected devices. You may need to have it tested or replaced.
  4. Check the automatic voltage regulator (AVR): If your generator has an AVR, it may be malfunctioning and preventing power from reaching the connected devices.
  5. Check the capacitor: While a visual inspection may not always be enough to detect a faulty capacitor, it is worth checking it with a capacitor tester to make sure it is functioning properly.
  6. Check the wiring: Inspect the wiring for any signs of damage, such as frayed or broken wires. If you find any, you will need to repair or replace the affected wires.
If none of these steps resolve the issue, you may need to consult with a qualified technician to diagnose and fix the problem.
2answers
How do you change a solenoid on a p6000s generator pramac ?
My Pramac p6000s fuel pump won’t work off the key but will if a put it straight to live on battery any ideas thanks
I require the valve clearance gap for a pramac p6000s diesel generator
If you need data of valve clearance gap of the diesel generator, you can check on the operation and maintenance manual. If still can not find, try to ask your supplier whom supplies the diesel generator to you.
If you need to have a generator set in future, please refer to www.dieselgeneratortech.com.
1helpful
Why my Pramac P9000 Generator does not start
Try a shot of starting fluid. If it does not start with that it may have a fuel supply problem.
ENGINE CUTS OUT, AS NOT CHARGING BATTERY.HOW DO I CHECK, CHARGING SYSTEM ON THIS MODEL?
you will require access to the end of the alternator from the drawings on the pramac site the alternator looks like it could be made by mec alte spa if so there are spec sheets on their site for the alternators, remove the end cover of the alternator and there should be a bridge rectifier in there which will need testing also the spec sheet should give the resistance of the coils so you can check them you will need info from the data plate on the alternator, if it is mec alte spa then find your product herehere
Top Pramac Electrical Supplies Experts
littlewheel
Ngoro
john h
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
