Question about Xact Communication XTR1 SIRIUS Radio Receiver
Sirius sportster got wet - Xact Communication XTR1 SIRIUS Radio Receiver
My sirius radio sportster works sometimes and others doesn't
Buy radio shack electronic contact cleaner (in a can) and spray a small amount on the male connector from the antenna wire, and spray a small amount on the male connector in the base of the Sportster that the sportster interfaces with. Place the antenna connector onto the base unit and remove it several times and swirl it while connected. Place the sportster into and remove it from the base several times. This usually will fix the issue. Sat signals are extremely sensitive to the slightest oxidation or dirt or whaterver on that tiny antenna connection point.
Oct 01, 2009 | Sirius Satellite Radio Sirius Sportster...
Can't get XM channels
Goto sirius.com. You will need to access you account and find out if your radio is upgradeable for XM channels. You can find that out once you try to add xm to your account.
If it isn't you can get a free or a discounted radio from them to do it by calling customer service up. They do that for existing customers.
Jan 17, 2009 | Sirius Satellite Radio Sirius Sportster...
When i place my sirius radio into the base, driver side speaker goes off and on but most time i only hear the passanger side speaker working, I had my sirius sportster for 3 years. I think it is the base,...
when you listen to a cd or the normal radio does the drivers side speaker work? if it does then it is most likely the base is the problem. you might have a loose connection in your car. or the speaker is blow.
Jan 01, 2009 | Sirius Satellite Radio Sirius Sportster...
Sirius radio
Cliff, If you mean a schematic then u are going to have a tough time finding that. It is manufactured by Directed Electronics, so you might try to contact them, but they might not be willing to divulge that info.
Feb 26, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Power but no signal
I work for sirius so I know about all of these different issues and the most common one is the connections. It is imperative that the radios be connected to power with the cig lighter adapter. This adapter had circuitry in it that lowers the cars 12 volts to 5 volts which the sirius unit ooerates on. The old units were 12 volt and could hard wired into the vehicles fuse block, but all of the new radios operate on 5 volts. If this is not the issue with either of you then you have defective units. Being that all warranty replacement are with remanufactured units, your chance of getting a problematic unit increases after the initial return of your new unit.
Feb 09, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
SIRIUS Sportster "Acquiring Signal"
Let me save you $30.00. A new antenna will not help, nor will cleaning the contacts. I just did both of those and it did not help. I have mine in the freezer right now cooling it down. Sirius told me that I should not leave it in the car because it gets to hot. They told me to buy another unit....
Feb 07, 2008 | Sirius Satellite Radio Sirius Sportster...
Sirius Sportster
Look at the bottom of your unit, you'll notice the round port next to the slot? It get's jammed up inside the unit if you pressed to hard setting it into the cradle at some point. Not easy to fix, unfortunatley.
Oct 22, 2007 | Sirius Satellite Radio Sirius Sportster...
Sportster 4 not working...
I had the same issue. This is what Sirius calls a "Frozen Unit". There is no bypass, unfortunately, and it must be returned.
I had mine for 3 days and it froze on the Sirius Logo screen when booting up. If you bought the unit from Sirius, you must contact their E-Commerce department. If bought from a retailer, take it back to the store.
Sorry, mate.
Oct 13, 2007 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Power supply to Sirius Radio
yes, some sirius radios work on 5 volts, and some work on 12 volts. Your sportster replay is a 5 volt unit. If you trace that wire back, you will find a cigarette lighter plug with a transformer built into it, with either wires soldered to the terminals, or a female cig plug wired up behind the dash. Whatever sirius unit you plan on hooking up, I strongly reccommend using the transformer that it came with......however if you're willing to take a chance, it's most likely 5 volts.
Aug 18, 2007 | JVC KT-SR1000 SIRIUS Radio Receiver
Sirius Sportster
Unfortunately this is a fairly common problem in the Sportster, caused by worn contacts in the tuner. Sometimes you can temporarily resolve the problem by wedging a thin piece of cardboard behind the tuner in the cradle, to create a better contact; but eventually it will just wear out again.
Jun 08, 2007 | Sirius Satellite Radio Sirius Sportster...
Xact Communication XTR1 SIRIUS Radio Receiver Logo
Top Xact Communication Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Xact Communication Audio Player and Recorder Expert? Answer questions, earn points and help others
