Dishwashers Logo
G
G Help Posted on Mar 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore elite dishwasher model 5770
The dishwasher fills - but when the cycle starts - it makes a noise like the motor is running but the wash arms are not moving. completes the cycle (whatever one I pick) but dishes do not clean at all. i cannot hear the 'swishing' of water at all.
John
Level 3:
  • Master 794 Answers
  • Posted on Mar 07, 2014
 John
Master
Level 3:
Answers
794
Questions
Helped
290861
Points
3169
3 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Apr 02, 2007
SOURCE: Dishwasher not getting water into spray arm, so no clean dishes
two possibilities: open door when in use. check if water is coming out of the spray arms. if it is and at a good rate, then the problem may be the spray arm jets blocked. the spray arms are only rotated by water coming out of the angled jets at their end or is the main circulating pump running ok?
Anonymous
  • Posted on Apr 21, 2009
SOURCE: Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Anonymous
  • Posted on Sep 04, 2009
SOURCE: Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Kenmore dishwasher making "spitting" or "sputtering" noise during operation
The easiest way to confirm if the arms are blocked is by turning all the arms in the machine to a certain same position and running the machine for a few minutes in its wash cycle. Open the door and see if the arms have moved. If not, check all the holes in the arms for blockages. Sometimes its very difficult to clean them. You may have to poke a pin or something into hole and then shake the obstruction out through the large inlet hole under the spray arm itself.
Kenmore Elite 5t shows an F30 code, water fill solenoid is making a noise like its not opening
This is a dispenser motor issue. If you pull the unit out and remove the 3 screws coming into the back of the top panel, you can remove the top panel to access the top of the dispenser. There is a motor that turns a plastic lever on the dispenser. you might be able to manually help the arm move to get past the error code, but ultimately you will need to replace the dispenser motor. Here is the part to order.
3helpful
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
1helpful
Buzzing sound
does it ever give an error code? a common problem on whirlpool made machines is the dispenser arm getting caught when changing positions. This part is in rear of detergent dispenser housing and uses a motor and a arm to select detergent/ softner/ bleach/ and fill. you can remove top (screws on back) to watch this.
6helpful
Dishwasher hums
empty out the unit and recheck the arm and rack then start it up empty and check operation --if huming but working properly --stated it does drain so motor is operating ---then its operating normal ---if arm still not working will need to remove arm and check gear or shaft for damage
GE Dishwasher won't fill (Tested valve and switches)
check thermostat it maybe overheat and gives a false signal that water is warm,it is on bottom.
2helpful
3answers
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
