Pool & Spa Logo
J
Jim Redman Posted on Mar 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sta Rite 400 btu heater. Replaced the manifold with tall the sensors. Replace the circuit board as well. Heater runs and keeps running just fine. After about an hour the temp in the hot tub only went up 6 degrees. It should have been at set temperature by then. Does the new circuit board need to be reset after replacing it?
David Spradling
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Sta Rite Master 1,448 Answers
  • Posted on May 08, 2014
David Spradling
Sta Rite Master
Level 3:
Renaissance:
Answers
1448
Questions
Helped
518466
Points
1901
Temp sensor is defective or heater element
5 Related Answers
Anonymous
  • 125 Answers
  • Posted on Feb 26, 2009
SOURCE: sta-rite heater Display shows 125 degrees, won't activate heater
sounds like the temp sensor is bad. Sta-rite Heater
Anonymous
  • 83 Answers
  • Posted on Jul 10, 2009
SOURCE: Temperature reads 125 degrees.
I am not sure if you have solved this issue, or not, but just in case. The problem is the Thermister, or temp sensor. That will need to be replaced since it is reading the water temp at 125.
The Thermister is located on the manifold, left hand side, between the first two bolts. It is pretty easy to change out and this will correct the problem.
Anonymous
  • 990 Answers
  • Posted on Dec 21, 2009
SOURCE: Water Temprature read 126 on heater and will not Fire
This is a problem with your thermister (heat sensor) You will find this on the left side of the water manifold about half way down. I'm not sure but I think it is a small tube that slides into the manifold and if you follow the wires back to the board it just plugs in. The part is reasonable priced for a heater part and very easy to install. Good luck.
Anonymous
  • 990 Answers
  • Posted on May 13, 2010
SOURCE: Ref: Sta-Rite Max-E 400. Pool temp is about 75
Your temp sensor has gone bad and will need to be replaced. It's a small tube that slides into the water manifold and you can follow the wires back to the board. Just unplug and set a new one in place.
Anonymous
  • 640 Answers
  • Posted on Aug 17, 2010
SOURCE: Sta rite Maxe therm heater turns on by itself
These pool heaters have a very helpful and easy to follow chart in their users manual for problems such as this one. There are questions that you will need to answer that you cant answer unless you are looking at the heater. Below is a pdf version of the manual.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
I have a Sta Rite 400 btu heater. Replaced the manifold with tall the sensors. Replace the circuit board as well. Heater runs and keeps running just fine. After about an hour the temp in the hot tub...
This is a curious situation. Where is all that heat going if not into the water? If the heater is firing normally, the water temp should be rising much faster, unless the bypass is stuck open. However in that situation the high limits should sense that the water is too hot in the exchanger and shut the heater off. Verify that your gas supply is sufficient, because after running for an hour that heat should show up somewhere. It's possible there may be blockage in the gas supply resulting in a low flame.
The heater ignites, stays on about 20 seconds and goes off, after starting and stopping 3 times, it displays a service heater light.
It may not be detecting that ignition occurred. There is usually a sensor that detects ignition and if it is not working right the controller tells yo to service the heater. If you call Sta Rite technical support number they may be able to help you determine what device needs to be replaced. I hope this helps.
3helpful
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Sean Wright
Sean Wright
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
