Black & Decker D2030 Iron Logo
A
Anonymous Posted on Mar 07, 2014
NO STEAM ON ANY SETTINGS - Black & Decker D2030 Iron
My Morphy Richards steam generator iron is intermittent with steam.
If your Morphy Richards steam generator iron is experiencing intermittent steam and you suspect a blockage in the hose, here are some steps you can take to address the issue:
  1. Check the water tank: Ensure that the water tank is filled with clean water and that the water level is adequate. Low water levels can affect steam production. If necessary, refill the water tank.
  2. Examine the steam settings: Verify that you have selected the appropriate steam settings on your iron. Some models have different steam intensity levels, so make sure you have set it to the desired level.
  3. Check for blockages in the hose: Disconnect the hose from the iron and inspect it for any visible blockages. Use a long, flexible brush or pipe cleaner to gently clean the inside of the hose and remove any debris or mineral deposits that may be causing the blockage. Ensure that the hose is securely reattached to the iron after cleaning.
  4. Clean the steam vents: Over time, steam vents on the iron's soleplate can become clogged with mineral deposits or fabric fibers. Use a cotton swab or a soft brush to clean the steam vents, removing any buildup that may be obstructing the steam flow.
  5. Perform a thorough descaling: While you have already used white vinegar for descaling, it's possible that there are still mineral deposits causing the blockage. Consider using a commercial descaling solution specifically designed for steam irons. Follow the instructions provided by the manufacturer of the descaling solution to effectively remove any scale or deposits that may be affecting steam production.
  6. Contact customer support: If you have tried the above steps and the issue persists, it may be best to contact Morphy Richards customer support for further assistance. They can provide specific troubleshooting steps or advise on potential repairs or service options.
Remember to always follow the manufacturer's instructions and safety guidelines when cleaning and maintaining your steam generator iron. If you are unsure or uncomfortable with any aspect of the troubleshooting process, it's recommended to seek professional assistance to avoid potential damage or injury.
The steam is coming out but no pressure when I press the button for the steam to jet out
If you're experiencing an issue where steam is coming out but there's no pressure when you press the button for the steam to jet out, there could be a few possible causes:
  1. Water level: Check the water level in the steam generator or steam-producing device. If the water level is too low, it can result in insufficient steam pressure. Make sure there is enough water in the device according to the manufacturer's instructions.
  2. Clogged steam vents: Over time, mineral deposits or debris can accumulate in the steam vents, obstructing the flow of steam. This can prevent the steam from building up pressure. Clean the steam vents thoroughly by following the manufacturer's instructions to ensure proper steam flow.
  3. Faulty heating element: The heating element is responsible for generating steam. If it is malfunctioning or damaged, it may not produce enough heat to generate adequate pressure. In this case, you may need to have the heating element inspected or replaced by a professional.
  4. Malfunctioning steam generator: If you're using a steam generator, it's possible that there is an issue with the device itself. Check for any error codes or warning indicators and consult the manufacturer's troubleshooting guide. If the problem persists, contact the manufacturer or a qualified technician for assistance.
  5. Incorrect settings: Ensure that you have selected the appropriate steam settings
May 20, 2023 • Irons
Not steaming
Steam Iron Not Working ' ThriftyFun
www.thriftyfun.com/Steam-Iron-Not-Working-1.html
Sep 4, 2013 - Here are questions related to Steam Iron Not Working. ... Why is my mini steam iron not working, after reaching 20 pounds of pressure? How do ...
My iron does not produce any steam - Philips
https://www.philips.co.uk/e/.../iron-does-not-produce-steam.html
PhilipsThe steam control may have been set to zero steam position. 2. There is no water in the tank and/ or the settings are not set correctly. 3. The steam vents of the ...
GC1015/31 Philips Steam iron GC1015 - Philips Support
Nov 18, 2015 • Irons
I cannot get my GCSBDS212 steam iron to make steam.
Have a look at the steam holes in the bottom, they should be nice an clean with no blockage. If they are blocked up you will need to remove the calcium buildup inside the iron. Get some LimeAway at HDepot, pour it into the water reservoir, let sit overnight. Next day turn the iron on and try steaming on some old papers covered with an old rag or towel, once it starts working steam for a few minutes, then unplug, drain it, put in clean distilled water and flush it out until the steam comes out clear. Use distilled water not tap water, it has much less mineral content and will be less likely to plug it up. Most pharmacies and Walmart sell distilled water. ! gallon about $1.25.
1helpful
My Tefal iron stop steam GV 8150
Hello :
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 • Tefal Irons
9helpful
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
3helpful
My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
Won't steam
The steam irons I have see have a separate button to allow water from the reservoir to enter the steam chamber. This button latches down for steam and you unlatch it for dry. Also, there is a temperature range on the temp dial for steam.
The reservoir must have water in it for the iron to make steam. If calcium from the water has built up on the reservoir valve, it may prevent the water from entering the steam chamber. Straight white vinegar instead of water may help.
No Steam
Your iron will only steam when it has reached the desired tempeture. When the yellow/orange light comes on and the dial has been set for cotton or linen it should steam, when you lower the top and push the steam lever
Top Black & Decker Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
