Parents bought me an Insignia ns-2brdvd for anniversary. Questions - can the digitical optical output send a signal when the HDMI hook-up is direct to my HD TV? My receiver does not have a HDMI input / output, so I need to run the audio to the receiver from the optical digital output, but want to retain the HDMI video output for the 1080p resolution. If so, what setting (if any) need to be set?
Below is what your manual says abour it. From hardware perspective, when you have a disc in there the optical audio driver is active and so is the HDMI audio. To verify, lift the lid on the optical interface and you will see a red or blue light on the inside. Don't look directly at it! View from the side.Plug that into your home theater system, select that input on your home theater and you should be good to go.
Insignia NS-BRDVD Blu-ray Disc Player
www.insignia-products.com
Connecting a digital audio optical system
To connect a digital audio optical system:
1Make sure that your player and the TV are
turned off.
2Connect one end of a digital audio optical
cable (not provided) to the DIGITAL OUT
(PCM/BITSTREAM) OPTICAL jack on the
back of your player.
3Connect the other end of the cable to the
DIGITAL AUDIO OPTICAL INPUT jack on
the digital audio system.
SOURCE: I have and Insignia Blu
the answer is yes. Insignia Blu Ray player NS-2BRDVD has firmware update like Sony, Samsung and other players.
If you are interested in updating your Insignia Blu Ray player NS-2BRDVD, simply click on the below link, read and follow instructions as to how you can download and install the update.
http://community.insigniaproducts.com/t5/Blu-ray-and-DVD-Players/Insignia-NS-2BRDVD-Blu-Ray-Player-Firmware-Update/td-p/281
You won't have any problem updating your Insignia Blu Ray player NS-2BRDVD as long as you follow instructions closely.
Good luck.
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
SOURCE: dvp5960 hdmi set up issues
You can disable the digital audio output in the audio tab at the setup menu.
SOURCE: insignia NS pdvd10
Unlock
Insignia NS pdvd10
It`s really works
1) On the remote control type "SETUP" button
2) Select "PREFERENCES" in the menu with
3) Validate it with the button "OK"
4) Enter the code : "224455"
5) With the direction keys type:
a) Left key : < (Nothing happens)
b) Down key : v (a menu appears on the screen
with all region)
6) Select the Region : 0 (all) with the direction keys
7) Validate it with the button "OK"
8) Finish the process by typing the "SETUP" button.
SOURCE: NS-2BRDVD Insignia Blu Ray Player
Install this firmware update: http://www.insignia-products.com/t-NS-2BRDVD_FW_Update.aspx
