Cell Phones Logo
A
Anonymous Posted on Mar 06, 2014
Gsm multi comport open error - KG LG Cell Phones
tip
Connect your mobile to pc for internet
hi i am Rajkumar...... after that just install your mobile modem connect your mobile with pc select com port option of your mobile than you find found new harwre in your pc install it now open your my computer ----->right click --->>>properties--->>harware ----------->>>>device manager---------->>com port-------->>> now see which comport is installed here......... now go to control pannel -------->>>phone and modem------->>>modem-------->>>>>>>.add-------->>>>next---------->>>next----->>media tek or mtk gprs -------->>>select the same port which you see in device manager comport---->>>>>.installed it........ now go to control pannel ------>>>network connection ----->>create new connection----------->>>>next----------->>>>>>>connect to internet------->set up mannually-------->connect using daial up modem----------->>>>>>select modem of same com port---------->>>write ur name---------->>>write *99***1# or *99# -------->>>select next--------->>>>next------->>>>>>finish
now go to control pannel -------->>>network connection--------->>select ur name and enjot your internet........... if there is also any just reinstall ur modem ,restart every thing and dial again....... bye .........
My nokia e63 wont receive calls, what is wrong please?
Go to settings->phone->network and changed the network mode from "dual mode" to "gsm". the other option there is UMTS. and that did the trick. you can always change back to dual as i remember on one of my old Nokia the phone wasn't detecting network and i had to do the reverse (from GSM to UMTS) to get it all good.
some notes:
-Universal Mobile Telecommunications System (UMTS) is one of the third-generation (3G) mobile telecommunications technologies, which is also being developed into a 4G technology.
-Unlike EDGE (IMT Single-Carrier, based on GSM) and CDMA2000 (IMT Multi-Carrier), UMTS requires new base stations and new frequency allocations. However, it is closely related to GSM/EDGE as it borrows and builds upon concepts from GSM. Further, most UMTS handsets also support GSM, allowing seamless dual-mode operation
Java games and softwarefor my china mobile s808
FIRST DOWNLOAD THE PC SUITE FROM
http://torrentz.com/ef43e280051c20f90ef6a440ecabdcdd7853fc74
IT IS A TORRENT SITE LINK
Basic features of PC sync Manager.
1)Download Java to mobile Phone.
2)Copy your phone book.
3)Copy your SMS.
4)Use your phone as modem.
How to use PC Sync manager:
-First download the PC sync manager and usb drivers.
-install pc sync manager.
-connect your mobile phone and select option COMPORT in your mobile.
-Install the drivers from My Computer rightclick->properties->hardware->balloon on Comport->install drivers.
-Select appropriate Comport from the PC sync Manager.
5helpful
I lost my drivers for gprs data card tri-band gsm/gprs 900/100/1900mhz gprs multi-slot class 10 model no.:Est600u mobile modem
i lost my drivers for gprs data card tri-band gsm/gprs 900/1800/1900mhz
4helpful
2answers
SECRET CODES
SAMSUNG UNLOCK CODE....
*2767*688# = Unlocking Code
*#8999*8378# = All in one Code
*#4777*8665# = GPSR Tool
*#8999*523# = LCD Brightness
*#8999*3825523# = External Display
*#8999*377# = Errors
#*5737425# = JAVA Something{I choose 2 and it chrashed}][/b]
*#2255# = Call List
#*536961# = Java Status Code
#*536962# = Java Status Code
#*536963# = Java Status Code
#*53696# = Java Status Code
#*1200# = AFC DAC Val
#*1300# = IMEI
#*1400# = IMSI
#*7222# = Operation Typ (Class C GSM)
#*7224# = I Got !! ERROR !!
#*7252# = Oparation Typ (Class B GPRS)
#*7271# = Multi Slot (Class 1 GPRS)
#*7274# = Multi Slot (Class 4 GPRS)
#*7276# = Dunno
#*7337# = EEPROM Reset (Unlock and Resets Wap Settings)
#*2787# = CRTP ON/OFF
#*3737# = L1 Dbg data
#*5133# = L1 Dbg data
#*7288# = GPRS Attached
#*7287# = GPRS Detached
#*7666# = SrCell Data
#*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while)
#*7284# = Class : B,C or GPRS
#*2256# = Calibration Info
#*2286# = Battery Data
#*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10)
#*2679# = Copycat feature (Activate or Deactivate)
#*3940# = External loop test 9600 bps
#*4263# = Handsfree mode (Activate or Deactivate)
#*4700# = Half Rate (Activate or Deactivate)
#*7352# = BVMC Reg value
#*8462# = Sleeptime
#*2558# = Time ON
#*3370# = EFR (Activate or Deactivate)
#*3941# = External looptest 115200 bps
#*5176# = L1 Sleep
#*7462# = SIM phase
#*7983# = Voltage/Frequenci (Activate or Deactivate)
#*7986# = Voltage (Activate or Deactivate)
#*8466# = Old time
#*2255# = Call ???
#*5187# = L1C2G trace (Activate or Deactivate)
#*5376# = ??? White for 15 secs than restarts.
#*6837# = Official Software Version
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*7638# = RLC allways open ended TBF (Activate or Deactivate)
#*7632# = Sleep mode Debug
#*7673# = Sleep mode RESET
#*2337# = Permanent Registration Beep
Mar 16, 2009 • Cell Phones
2helpful
Multi region code
please try this
open tray
press 98790
OR
Keep Tray in eject position
Press Setup from remote
Go to preference page
Press"138931"
Using Navigation Key chane region code to "0"
Press "OK"
hope it helps!
My Com Port keeps on failing, which causes Loader 2 for my ViewSat Dish , not work and that is a problem because i need to enter a code into the cable frommy computer.
On the loader program go to fileicon then auto find com port or just try each comport setting example com port 1 comport 2 and so on till it works hope i gave you a fixya:)
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
