Sewing Machines Logo
A
Anonymous Posted on Mar 06, 2014
Adjusting tension Top tension is too loss
Janome 6500 Sewing Machine. CORRECT TENSION ON 6500 JANOME SEW MACHINE please.
Question edited for clarity.
Please don't type in all CAPS, it is considered SHOUTING and is harder to read.
Sewing machine tension is a delicate tug of war between the bottom Bobbin tension and the Upper tension to put the loop between the 2 layers of fabric. You set the Bobbin tension first and the the top tension depends on the fabric and the thread used.
Your Bobbin tension is very very loose to be not tensioning at all or the top tension is too loose.
Adjusting The Tension - Janome Memory Craft 6500 ...
ManualsLib https://www.manualslib.com > ... > Instruction book
Janome Memory Craft 6500 Professional Manual Online: balancing thread tension, Adjusting The Tension. Correct Tension: The Ideal Straight Stitch Has Threads ...
Best video on tension
What are the tensions for the husqvarna 105 sewing machine please
Not sure what you are asking. The standard factory setting for top tension is the midway point on the dial. On a lot of machines, it is marked in red. The bobbin tension is set by a technician. If it has been adjusted, it will affect both bobbin tension and top tension. That is why it is very important to make attempts to resolve a tension issue by adjusting the top tension BEFORE adjusting the bobbin tension as a last resort.
1helpful
2answers
How to adjust tension
Tension is most often adjusted at the top tension dial. Only in extreme cases where the top tension does not make the needed adjustments would you need to adjust the bobbin tension. Also, bobbin tension is very sensitive and can easily throw your machine into a tizzy.
Basically, sewing machine tension is simply a tug-of-war between the top and bobbin thread. When they are equally matched, the threads will meet in the middle of the fabric. This is the optimum tension for most sewing. If the bobbin thread is coming up to the top of the fabric, the top tension is too tight--loosen it. If the top thread is going to the underside of the fabric, the top tension needs to be tightened. The higher the number on the dial, the tighter the tension.
FWIW, tension is static. It is not one of those, set it and leave it forever deals. Whenever the fabric, needle, thread are changed, there's a good chance the tension will need to be tweaked.
Understanding Thread Tension Threads
Pfaff needle thread tensioner on a 1471 isn't adjusting properly. How do I gain access to the discs to determine the problem?
Install a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread the top from the beginning.
Set the top tension to the midway point and try your machine again.
If there are still issues with the top tension and adjusting the tensioner isn't working, there may be gunk, lint or thread stuck in the tension disk. Remove the top thread. Set the top tension all the way to Loose. RAISE the presser foot. Dip a length of perl cotton in rubbing alcohol, squeeze out the excess, and then "gently" pull the perl cotton "DOWN" through the tension disk a couple of times. See if that helps.
Model 1507 tension
I'm sorry, but you will have to be more specific. There is a top and bottom tension. The top tension is adjusted using a dial of some kind, visible on your machine. It has numbers on it; generally the lower the number, the tighter the tension. The bobbin tension generally does not need adjusting, although it can be adjusted. Please write again to let me know what it is doing that leads you to believe the tension needs adjusting.
Dec 11, 2013 • Singer 1507
2helpful
2answers
Tension is messed up on my 96ksv7
Keep adjusting the tensions top and bottom until you get it right
Thread is bunching up from bobbin side think tension needs adjusting
I assume you have tried adjusting the top thread tension and are referring to bobbin tension adjustment. Before you do anything, with the bobbin properly threaded, manually pull out some bobbin thread. There should be resistance, just like the resistance you feel when you pull on the top thread with the foot down. Bobbin tension adjustment is by means of a small screw in the bobbin assembly. Mark the screw head position before you start adjusting it (so you can return to that position should you need to). Make small adjustments (1/8 turn of the screw) in each direction and see if it helps the problem. Be aware that thread tension is only one of many problems that can result in faulty stitches.
I can't find the tension adjusting spring on my brother 2600i
1Sew a test seam. Ads by Google
'; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9911500640+9665908481+7416705818+8962074949+8941458308+1258424658+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); 2Observe the seam on the top and the bottom surface using a magnifying device if need be.
  • 3Find the position of the knots.
  • 4Tighten the tension and "pull the knots up" if the knots appear on the bottom side of the sewn seam.
  • 5Loosen the tension and "drop the knots down" if the knots are on the top surface.
  • 6Sew a test on the fabric you will be using. Tensions often have to be adjusted when changing fabric types and weights.
  • 7Continue adjusting the tension and inspecting the seam until your seam is balanced.
  • 1helpful
    The top thread is really loopy on the underside of the fabric, sometimes it misses a stitch, sometimes, the upper thread breaks, and it often gets so tangled underneath that the machine won't feed.
    Your tension is way too loose on top or too tight on the bobbin. Try adjusting the top tension one number at a time until you get it right. (Only adjust the bobbin tension as a last resort). Also you could have different thickness of thread in the bobbin than on the top or are sewing a very heavy fabric. Try adjusting the tension with same thread in both bobbin and top and use a normal weight fabric until you find the right tension to get you back to a normal stitch before going to a heavier fabric or thread.
    Sudden knotting under fabric
    I have an Elna 2005 machine and had a similar but opposite problem whereby the tension up top was too tight - thread wouldn't pull smoothly. I found adjusting the feed dog lever slightly helped the stitches a lot, even though the needle tension up top is no better. Hope that helps! :-s
    Top Janome Sewing Machines Experts
    ZJ Limited
    ZJ Limited
    Kolbrun...
    Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
