I need a motor drive coupler asap!
SOURCE: Do you know where I could find these opto-couplers?
when you look into the back of the set you will see a small board on the far left. The large board right next to the small board is where they are located on that board usually near the back edge of the board closest to you roughly in the center. You can try at the following link just leave them an email with the model number of your set and what youre looking for, They usually can get the hard to find parts. Heres the link.
http://servicemanuals.vstore.ca/
SOURCE: replace parts
call 18005441108 -- they will provide you with any replacement part needed -- just have credit card ready!
SOURCE: thermo coupler on all the time, push in button, shuts off gas
Bad Safety valve. (valve w/red button). Thermocouple keeps the magnet open to keep pilot and so gas can flow to burner. Make sure pilot is clean and strong and hitting thermocouple. If it doesnt stay lit replace Safety Valve.
SOURCE: I have a Kenmore washer #110 92380200 that will no longer spin or
STOP STOP if you lay it on the back watch the drain hose you will see the pump 2 clips..undo by sliding clips over edge take hoses off pump and remove pump.unplug motor connector plug wires 2more clips hold the motor but they have screws in them you need to take out push them off then pull motor out change coupler PUT THREE BOLTS IN TUB BACK...
SOURCE: Replacing screw drive socket coupler on chamberlain garage opener
There are two bolts just in front of the motor that holds the rail. Remove these and you can move the motor back enough to slide the coupler off.
