Hi just read your posting.When you say the water is leaking out of the top ,does that mean it is leaking on the floor or leaking into the bowl even when the machine is off.If it is leaking into the bowl then it is a faulty water valve.Turn off the cold tap and leave for an hour and see if the water stops and if it does stop then the problem is the cold valve.If it doesn"t stop the leak turn the hot off and leave for an hour and see if that stops the leak.By memory I think your water valves are a double unit and to change one you must change both.Please reply with additional information about where the water is leaking to and I can help you rectify this fault,
If water is leaking from a pipe. then replace or repair the pipe or fitting. If the leak is coming from the unit itself, then replace the unit. Hope this helps.
If you are sure the water isn't leaking somewhere - run the car stationary and look for spots on the floor - then is lost thru evaporation. Look at the caps of the radiator and the state of the expansion bowl.
this is most likely the water pump if it is leaking at front of engine, the water pump is under the large timing belt cover and driven by the timing belt, so both are changed at the same time.
