When ever you have a questions about a KEB Combivert inverter, it is best to provide as much information as possible. At a minimum provide the following:
Part# or art-nr
Serial # or ser-nr
Fault codes
Type of machine
Machine manufacture
Problem description
KEB manufactures many different types of F5 inverters and each type has different hardware, software and functionality. With the above information it is easier to provide a better solution to the problem.
Get onlineand got to www.google.com In the google search box type: "FujitsuSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
Check wether the processor cooler is still working. If it isn't , I can help you get a new one.
If it is, rmove the disket station, see if tht helps. If you can then boot, first install the drivers for the station I can help find them), if there are any, then build it back in.
If that doesn't help either, take out again, update your BIOS (I can also help with that) and build it back in.
Let me know what happened soon,
Yannick.
you have to buy a toshiba FDD attachment case which plugs into the computer.I have the opposite problem.. I have a built in floppy drive but I must buy a cd-rom .
