Hello. First i would check the outlet that its plugged into. If plugged into a wall outlet, check to see if the circuit is tripped. Might have to reset the circuit. Next try a different power outlet. Unplug the power cable from the back of the printer and plug back in. If still not working, try a different comparable power cable. If that don't work either, check to see if the printer is under warranty with Lexmark and call the customer support line and see if they can place service on it. Hope that helps
1. Printer should have power 2. Disconnect the power cable from back of the printer. 3.While holding the power button, connect the power cord back to printer. Release the buttons are 2-4 seconds. 4. It should start working
I found this on another website and it worked for me. It apparently resets the printer. Hope it works for you:
1.) power on (error message) 2.) press the "Stop (triangle)" and the "Colour copy" button and hold them 3.) press the power button to power off, still hold 2.) 4.) press the power button to power on, still holding 2.) 5.) the LEDs start to flash, then they stop to flash and the red exclamation mark starts to flash. Now release 2.)
6.) the LED should say: "Init EEprom" 7.) now press and hold the power button until the printer powers off and powers on again.
check to make sure the socket is working if not check the power box and see if a switch jumped during the power out sounds like thats all try plugging the printer to a power source you know works
Hi, to perform a self-test on an Epson LX300 > start with the power switch off. Press LF/FF (middle switch), without releasing that button, power on the printer. If everything is ok it will print a sel-test page. To do a Hex Dump > start at power off, simultaneously press Font and the LF/FF buttons (left & middle buttons), then power on; to revert the printer to its factory default setting(s) > start in off position, press Font (left) button then power on. (Slightly different with an LX300+) Hope this works out for you. Cheers.
