When i turn on printer after that come on the ready condition mean green light on.but when i green light push for 5 sec then blinking attention light .what's the problem inside.i don't understand you can tell about plz
Go To Below official HPPrinter Page For Your problem, HP Support document Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For HP Support
SOURCE: Model : HP LaserJet 1320
Hi, If that is the only light on (blinking or not), then you probably have a paper jam or a door open somewhere on the printer. Make sure both doors are closed securely at the back of the printer. Make sure that the toner cartridge is secured inside the printer. You not only have to just insert it, but you have to insert it until you can feel it lock into place. Make sure there is no paper jammed inside the printer or inside the rear doors. If you have a blinking light AND the power light is ON, press the GO button. This is also a sign that a complex print job was sent that max'd out the installed memory. Hope this helps!
SOURCE: hp laserjet 1320 problem
This is an error state that is not described at HP site.
Try to do a hard reset:
1) Turn off the printer
2) Press and hold down the green GO button
3) Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
4) Release the GO button.NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
5) The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
Hope it will help you
