Dear
You have not mentioned the model. However you can download the SAMSUNG EASY PRINTER MANAGER which can show which door is opened. The door has a leaver which close the switch inside the printer to acknowledge the door is closed, either the lever broken or mis-aligned. You can check it with a insulated plastic knife pushing the sensor switch.
hope the above may get you some idea.
thanks.
Testing Mode
1. Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then‘SPEED DOWN’ and hold buttons pressed simultaneously
2. LED scanning mode for verifying display functionality
3. Press ‘ENTER’ to scan DATA LINES to verify display functionality
4. Press ‘ENTER’ to scan SACN LINES to verify display functionality
5. Press ‘ENTER’ to scan LED’s to verify display functionality
6. After pressing ‘ENTER’ the TIME window shows “test” and the
keypad functionality can be tested (the value displayed
changes when a button is being pressed)
7. Press ‘ENTER’ to enter IO mode (TIME display shows lift
motor potentiometer value, SPEED reads speed from speed
sensor and DISTANCE shows heart rate pulse)
Press ‘START’ to test lower board relay (a “click” sound)
and then press ‘ELEVATION UP’ for 2 seconds to increase
the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum
percentage 0%
Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ to decrease speed value.
Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return
to the normal mode
Use the following procedure to turn off wave protect: 1. Power on while holding SETUP and WAVE ("Welcome to SPD-S",
followed by "wave protect off" will show momentarily in the display). Note: Repeat the procedure to turn wave protect back on.
The card I have always been using is now also suddenly giving this
message. I found an old SanDisk 16MB and a 1GB SanDisk that works
perfectly in my Boss 864 and they also give the same message. Trying to
go into formatting brings the message "no card!"
