Air Conditioning and Heat for Jaguar XK8 Logo
A
Anonymous Posted on Mar 06, 2014
Blower weak in 1997 jaguar xk8 - Air Conditioning and Heat for Jaguar XK8
Bruce
Level 2:
Sergeant:
  • Expert 311 Answers
  • Posted on Jul 28, 2014
 Bruce
Expert
Level 2:
Sergeant:
Answers
311
Questions
0
Helped
104307
Points
771
More than likely is the "Blend Door", a common Jaguar problem - most all older models.
Go to http://www.jaguarforums.com/forum/xk8-xkr-17/ and search for specific problem, answers abound.
2helpful
2answers
1997 Jaguar XK8 Convertible. Can convertible top pressure hose be repaired other than replaced? Is there a kit?
Question edited for clarity and typos.
Question moved to model category.
No of course not. the hoses are under extreme hydraulic pressure, that is what makes them rupture, you can't repair them.
Here are the hose kits
https://www.google.com/search?q=1997+Jaguar+XK8+Convertible.+convertible+top+pressure+hose
1helpful
1997 Jaguar XK8 convertible top.
Question edited to add maker.
It appears to be a known issue. Videos that may help.
https://www.google.com/search?q=1997+Jaguar+XK8+convertible+top+will+not+raise
Need time chain/gears /sprockets /tensioners replacement diagrams and replacement procedure on 1997 xk8 jaguar. Dennis [email protected] 813 967 7127
If you send a letter to this address he will have all the parts you want.
101,Ripon Street (North)Lake Wendouree Ballarat Vic
3355 Name is D.A.Wain.
1997 XK8 Transmission Failure. Will 2001 XK8 transmission work
I had a similar problem with my 1997 XK8. Apparently the transmission will not last much more than 100,000 miles. You need to replace the clutch in the transmission - cost between $2,500 and $4,000.
2helpful
Jaguar XK8 Remote Locking problem
check your lock relays located in the interior fuse panel. Sometimes the actual connections to the fuse block can come lose and the relays wont work properly. My 2000 silverado did the same thing till i bent the pins on the relay for a tighter fit.
hope this helps
1helpful
I want to clear check engine light on 2002 jaguar xk8
go to autozone have them scan it and then clear it record the trouble code and then clear it another option is disconnect the battery both positive and negative and make a jumper wire between the 2 terminals make sure that you disconect the battery very importan
Need source for new 1997 XK8 convertible front coil springs
Hi
Yes front coil springs are what you need !
I think the spares situation for Jaguars, is disgusting with the main dealers.
I have been trying to source them myself, for about 2 weeks, and only found ****, painted up second hand ones.
I will keep trying, and let you know if I am lucky and find a source for genuine new springs.
Best Wishes
John
Top Jaguar Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Denis Houle
Are you a Jaguar Vehicle Part and Accessory Expert? Answer questions, earn points and help others
