husqvarna 142 e will use 91 octane fuel is ok and use qood quality 2 stroke oil
at the ratio of 50:1 premix that is 20 mils of 2 stroke oil for 1 litre of petrol that you mix
so if you want to make a 4 ltre mix add 80 mils of 2stroke oil to clean container and add 4 litres of petrol only and give good shake then fill saw
Go to Searspartsdirect.com and enter the complete Sears model number minus the decimal point. That should bring you to a series of replaceable parts diagrams plus part numbers. If the bolt is not listed as a separate part, then likely it is part of the fuel tank assembly. Hope this helps!
You need a coil spring compresser, and the proper skill level to use it.
If you try to change the coils without a compresser, you CAN & WILL GET HURT. Coil springs are not something to fool about with if you do not have the proper tools. These things are danagerous.
