I'm currently working on figuring out what's wrong with this monitor, and there are no helpful solutions so far. It is a 19" ViewSonic VA912b LCD monitor, with VGA and DVI input. Whenever I try to power on the monitor, the screen flashes on with a small blue box right in the middle of the screen, followed by the screen immediately fading out to black, then the green LED that shows that there is signal goes right to yellow and nothing else happens. The text in the box is too small for meto read in such a short amount of time that it is there. Has anyone else come across this problem? If so, what can be done to fix it? I'm thinking the circuit board could just be shot...
It is probably the power supply, or the inverters.
Similar problem with solution, though it requires you to know something about electronics.
http://www.badcaps.net/forum/showthread.php?t=6876&highlight=*va912*
Testimonial: "Problem Solved! Caps were spilling out all over the place. Sorry it took so long to reply >.<"
The monitor also has this behavior without the cable plugged in with just power being supplied. I noticed the text said, "Analog" and that's when the picture dies out. Anything would be helpful.
