Select a lock screen scene or personal photo to display on the lock screen of your Fire phone.
From Settings, tap Lock Screen, and then tap Select a lock screen scene.
Swipe down through the available scenes, and then tap to preview the lock screen. Alternatively, tap Your Photo to select a personal photo to display.
Tap the checkmark to set the lock screen or the X to cancel.
By default, your phone will rotate through all of the available lock screen scenes daily. To turn this feature off, tap Off next to Rotate Scene Daily at the top of the screen or select a specific scene.
Note: When the battery is low on your Fire phone, Dynamic Perspective lock screen scenes will stop reacting to your movements to conserve battery life. From time-to-time, we will add additional lock screen scenes to your Fire phone when they're available.
Screen lock has been turned off Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lock/Unlock Screen Portrait Orientation Mode - Apple® iPhone® 5. This helps if you can't get the screen/display on your device to flip or rotate. Access the Control Center by touching the bottom of any screen then dragging upward. Tap the Portrait Orientation icon to lock orunlock screen portrait orientation.
Locking and unlocking the screen If you do not use the phone for a while, the screen will be automatically turned off and locked. This helps to prevent accidental taps and saves battery power. When you are not using your phone, press the Power/Lock Key to lock your phone. If there are any programs running when you lock your screen, they may be still running in Lock mode. It is recommended that you exit all programs before entering Lock mode to avoid unnecessary charges (e.g. phone calls, web access and data communications). To wake up your phone, press the Power/Lock Key . The Lock screen will appear. Touch and slide the Lock screen in any direction to unlock the screen. The last screen you viewed will open.
Customize the Lock Screen By default, the Galaxy S4 lock screen isn't the most interesting or useful lock screen we've ever seen. Its functional sure, but for those of you who like a bit more action in your lock screen, there are a few things we can do to improve it.
