https://www.manualslib.com > ... > Stereo System
Manuals and User Guides for Aiwa XR-X7. We have 3 Aiwa XR-X7 manuals available for free PDF download: Service Manual, Operating Instructions Manual ...
you can use the Nokia Pc Suite ( http://europe.nokia.com/pcsuite ) after download and install the application on your computer connect the x7 by the usb cable or Bluetooth then u will have 3 different options:1) export the messages to a single excel file2) drag and drop the messages from the communication centre to the desktop then drag it and drop it again in the place after connecting the n93) use the backup option to backup the messages and restore them to ur new nokia phone (not guaranteed to work all the time though)
Hello, You Can Reset Your Nokia Phone X7 . Call Your Network Provider To Ask Your Nokia Phone Unlock Code. But your Network Provider Takes Time To Give You Unlock Code. If You Want Your Imei Unlock Code Instantly. Buy Nokia Imei Unlock Code From Third Party. Many Sites Available Online To Provide Imei Unlock Code. I Hope This Will Help You. Thank's
in order to be 100 % sure
you would have to check voltage to the motor while its suppposed to operate
take off the bottom 6 screws, you might need whats called a safe t, a torque wrench or star with a hole
most use phillips,
drop the bottom, you should see the turn table motor
disconnect the two leads and connect them to a voltmeter,,,
turn the unit on
you should read voltage to the meter
if not the problem is in your control board and will need to be replace
if you do read voltage and the motor is not turning
you will need to replace the actual motor
either way its a pretty simple repair and can be done without taking the unit dwon
