Belling XOU482 Electric Double Oven Logo
Posted on Oct 29, 2007
Belling Format cooker
I have a secondhand Belling Format cooker.  Don't know where to find the model number, but it has two ovens.  I cannot get the setting on the large oven to come off auto.  As a result I cannot switch it on manually.  I cannot seem to access a user manual online, so am stymied.  can u advise, on how to fix the problem, and how to access a manual?
  • bron1805 Jul 15, 2008
    I have the same problem- how do I get it off auto please?
  • Anonymous May 11, 2010
    I have a belling foemat 652 the main oven wont heat up, the fan works as does the rest of the cooker can anyone advise
jackdaniels1
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 01, 2008
jackdaniels1
Contributor
Level 1:
Answers
Questions
0
Helped
4342
Points
8
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section. http://www.prestigeappliances.com.au/owner's-manual.shtml
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5278
Points
None of the buttons work on my berling format cooker , and it comes up with auto , what should i do ?
Anonymous
Level 1:
  • Posted on Feb 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4342
Points
Try reducing the cook time to zero and then press the manual button. This should return the cooker to manual
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
Free standing belling cooker model numbers
try pushing 2 buttons on left and 2nd button in from right side
push left ones first then the other! should stop it.
Could try pulling buttons out and then replacing them best is to consult a local engineer!
warmest regards
Richard The Repairman
Mar 28, 2014 • Ovens
2helpful
Cant find the model number on a Belling Format cooker
Hi.
Try looking inside the oven, or at the bottom front
Nov 28, 2008 • Ovens
Belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
1helpful
3answers
Belling multifunction user manual
modle number 44445847
is that all you need?
Jan 06, 2008 • Ovens
Top Belling Ovens Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
David Spradling
David Spradling
Are you a Belling Oven Expert? Answer questions, earn points and help others
