My aspire 4333 does't have bluetooth,so what shall i do?
SOURCE: bluetooth location on acer laptop
Bluetooth other than the device itself is software, the "bluetooth dongle" gets plugged into a port via the usb, So I am thinking you need to plug it in to the computer. If it is a new machine if may be internal, that would be under programs, start programs, if no bluetooth it must be installed the software and hardware, good luck
SOURCE: bluetooth and IRda in Acer aspire 5320
Click the Start button , click Control Panel, click Printers, and then click Bluetooth Devices. Nearby devices are listed on the Devices tab. First, you must have another Bluetooth device near you, it will not activate alone.
SOURCE: acer aspire 5500z driver bluetooth
First of all check if your Laptop has the bluetooth feature. If it has then the driver should have been automatically installed. There is a button in your laptop, make sure that the bluetooth is on.
Thanks
SOURCE: my bluetooth is not working on my acer aspire 5738
If you do not have a white sticker on your laptop with" Bluetooth" stated your machine does not have one, only the ability to run one once installed, check the acer website for details, downloading lots of drivers will not work if you have no module installed, most do not.
SOURCE: Activate Bluetooth on Acer Aspire 6530
Dear craigpawlak,
I think the problem you are facing is an issue with drivers.
to ensure this is a problem as I mentioned, follow the following steps:
There
you will see the drivers installed for your PC and see if any hardware
list is accompanied by a question mark that's the hardware driver is
not installed.
Solution to the problem is to install drivers Bluethoot, you may get in the cd when you bought it. if you do not have it, then I'll give the link to get these drivers. (available for Vista and XP). Click here to download driver
How To Install Driver ?
Do not hesitate to contact me if there is a problem or my explanation is less understandable.
regards.
