.Traction Control System. The traction control system works in conjunction with your Antilock Brake System (ABS) and your Engine Control Module (ECM) or Powertrain Control Module (PCM) or Electronic .
You seem to have no question here? Yes I agree that your tracktion control is tied into other parts of the vehicles electronics. It is basically a way to apply brakes to tires that may easily be spinning on ice or mud. It will stop the whels from digging a hole by stopping the free wheeling spinning that may occur right when you put it in gear and let off the brake. If you have any wheels that spin even without giving any gas, it will brake those wheels and shift power to the other wheels that are not spinning in an attempt to drive the vehicle in the selected direction of travel. The wheels will not dig a hole and get it stuck as quickly. The Brake system detects the spinning and sends it to the ecm to check the throttle position, if no throttle is being applied then no wheels should be spinning at a rate faster than what it has recorded in it's memory under normal driving. Then the brakes are applied to those and the pcm will transfer the power to the non spinning wheels.
Dynamic Rear Proportioning (DRP)
Traction Control System (ETS) (w/NW7)
Traction Control System (TCS) (w/NW9)
Vehicle stability enhancement system (VSES)
