SYMA Toys industrial New Syma S107 Radio Remote Control Helicopter Logo
A
Anonymous Posted on Mar 05, 2014
The wires to the rear rotor have disconnected inside the helicopter. where do I reconnect to.
I would like a wiring diagram to reconnect the wires to the rear rotor.
Tail rotor on gs hobby helicopter not working
use a meter to test wires and motor for short s
Jun 02, 2017 • Hobby Toys
Rotor spins while charging
You have a bad flight control board. There may be a loose wire near 5be charge port making fontact wi5h the output circuit for the main rotors. Good luck
Just got a s301g Helicopter and it won't start up
Check the wiring where you plug in the charger to the helicopter. There is a red wire with quick disconnects. If its loose (the quick disconnect) you get this problem. In my case the helicopter came out of the box with this completely disconnected. It was hard to connect because there wasn't enough slack wire but once we did it the white light on the front of the helicopter came on and we were flying.
Hi I have a gyro helicopter which spins in circles after taking a hit... Its a Police Gyro Helicopter from thumbsupuk Do you have any solutions for this? Thanks
Make sure that the balancer wheel/rotor at the rear is not damaged while it had the fall/hit.
If so make sure that the tails is rectified. Once the rear is damaged the helicopter stabilizes on the movement of the rear rotor as the top main rotors need a counter balance.
So it is possible that this mechanism is damaged and must be recitfied.
Dec 30, 2010 • Toys
My Yiboo Micro Blade Rc copter won't charge. I've tried disconnecting and reconnecting the batteries, but every time I plug it in the charging light doesn't come on and it goes into transmitting mode....
Well my K11 helicopter that I bought from Paddys Markets Sydney Australia last week for $45 gave up after three flights. I suspect the battery is either dead or not charging or a burnt out wire. I suspect your micro RC helicopter has a similar issue. I smashed open my charger with a dumbell weight to see if the wiring inside it was ok. All looks good, but when it is plugged in, it does not even produce heat, which chargers always do to a certain amount. I also dismantled helicopter and took out battery. For $45 it is not worth me buying a voltmeter, another charger (which I cannot find online) and my manufacturer has a dodgy website as well! I recommend keeping your toy for parts and maybe getting another one?
2helpful
How do I remove the bake element in a CFEF365RIS1 FRIGIDAIRE ELECTRIC RANGE.
  1. disconnect power
  2. remove screws holding bracket to rear inside wall
  3. pull element out slowly and disconnect wires,pull off
  4. if wire disconnects while pulling element out you'll need to remove rear panel to reconnect
  5. hope this helps,please rate my solution :)
2answers
Airhog helicopter
yes u can
Jan 01, 2009 • Toys
Top SYMA Toys industrial Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
