MFC-7820N was made and described in Holland. I wish to change the instructions to English? i have a print-out, but do not know what it says.
Uninstall the printer and scanner software, disconnect the printer from the computer, then reboot your machine.
Once rebooted, insert the installation disc and follow the instructions (Make sure you choose the english language installation). Hopefully, when installation is complete, everything should be in english.
If not, go to brother.com and download the english installation for your printer, then follow the instructions above.Still having Problem Then follow Us For:
Brother Printer Support
SOURCE: change language back to english on epson cx4800 all-in-one printe
Download teh ENGLISH driver from www.epson.com
UNINSTALL the old driver
INSTALL the new, if it asks to use existing driver or new, choose USE the NEW one
SOURCE: How to reset Language
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1. Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
SOURCE: language changed
Press Menu, go forward (right arrow) to the 4th option (Maintenance), hit enter, hit left arrow once, and enter. This is the language setting. Select language, press start, select country, press start.
SOURCE: how do i change the language?
I have Brother DCP-130C all in one Printer.
When I installed the
software I chose English as the language, but when i am scanning &
when i go into printing preferences it seems to be in German. I
un-installed & re-installed but still not in English.
Any ideas how I can change the language to english please?
