I was using my phone talking to my girlfriend and it randomly froze while i was typing and wont stop vibrating. i cant lock it or turn it off. please help im going on vacation in 2 days and need my phone
SOURCE: My cell phone wont ring!!!!!
May be you selected the " Silent Profile " by accident in settings. Go to Menu > Settings > Profiles > and see what you have Choose something other than Silent and Activate see if your phone rings !
SOURCE: im locked out of my phone i dont remember my security code
Try the last 4 digits of your phone # and if that doesn't work call up the place that you purchased your phone from and they should be able to help you out.
SOURCE: vibration for text message
I use an HTC Touch. Hopefully the menu should be the same in Touch HD as per the Touch. Try this..
Start -> Settings -> in the Personal tab, click Notifications -> u might see 2 tabs -> select Notifications tab again -> select an Event (here it is incoming SMS) -> below you'll see the Vibrate option -> tick on it to enable it -> Select OK to save.
Hope this helps, If so, rate me.. thanks - billa..
SOURCE: i i forgot my phone lock code for my samsung sgh-f480
hard reset *2767*3855#
All Samsung Hard Reset Codes
In those steps:
1.)*2767*3855#
2.)*7465625*638*00000000*00000000#
3.)#7465625*638*00000000#
Now your phone is unlock forever Permanent
Here is Samsung F480 Secret Codes
Admin Settings: *#6984125*#
Admin Settings
Internals (sub menu): *#9072641*#
Developer Settings: *#0523#
Camera test mode:
Press *#36287# key string in the dial screen to enter camera test mode -
[1] Auto focus [On]
[2] ISP firmware write
[3] ISP firmware version check
[1] Press the "1" key to disable auto focus. In order to enable auto focus, press the "1" key again.
[2] Press the "2" key to write the ISP (Camera Module) firmware. “ISP firmware write [Please wait]” will be displayed during 2 minutes. Then "ISP firmware write [SUCCESS]” will be displayed when the firmware upload finished.
