D-Link DAP-1320 Wireless Range Extender Logo
K
Karen Storthz Posted on Mar 05, 2014
Connect D-Link DAP 1320 to 3800-HGV
Cannot connect to 2wire 3800-HGV
2 Related Answers
Anonymous
  • 42 Answers
  • Posted on Aug 31, 2009
SOURCE: i am trying to port forward d-link DCS-2121 camera
Instead of walking you through it here, it will be much simpler (for me, and probably you too!) if I link you to the most informative database on the subject ..and a page dedicated to your 2WIRE:
http://www.portforward.com/english/routers/port_forwarding/2wire/2701HGV-E/default.htm
Anonymous
  • 825 Answers
  • Posted on Aug 20, 2010
SOURCE: I have a d-link dwa125
the security enabled in the router is compatible with mobile but not with computer this is the reason...check the security enabled in your router...64 bit WEP (open) security is compatible with all the wireless devices... by default some routers will have WPA or WEP(shared) security... these securities are not compatible with certain computers...
Why i can not go to sit for configure DAP-1360
Go to this link http://support.dlink.com/ProductInfo.aspx?m=DAP-1360 and download the user manual for your DAP-1360. Configure it in the WISP mode following the manuals instructions.
My d-link DAP-1320 connects to my wireless airport extreme but not internet
REINSTALL THE DRIVERS AND SOFTWARE FOR DLINK. TRY A DIFFERENT TYPE OF USB WLAN.
2answers
I configure a DAP-1150 and can connect via a laptop but my iphone and ipad fail to connect it. However, when I reset the DAP (with no security), the opposite happens! It means that my iphone and ipad can...
That is because your laptop has the saved connection history that you need to delete. Since your acces point does not have security which is not the same as the one that saved from your laptop. Therefore, your laptop won't be able to connect. Go to network and sharing center and from the left side of the page that came up look for change wireless adapter settings and click it. You will be able to see the connections that was saved and the top one would be your connection name. Delete that and close everything. Try connecting to your wireless network again and that should resolve the issue.
I have a d-link dwa125 wireless adapter that wont connect to my 2wire 2701 hgv-w wireless router. I can connect my sony ericsson xperia x10 to it but when I use the same password for my computer it wont...
1helpful
I am trying to port forward d-link DCS-2121 camera to 2WIRE 2701 HGV-E. pls help a complete idiot.....
Wireless Devices won't connect to 2Wire Modem
change the channel. this is a common problem when wireless routers are broadcasting on the same channel and at times, some cordless phones will interfer as well.
good luck
How do I connect a Linksys Wireless-N Model WPC600N to a 3800 HGV-B Gateway modem/wireless router use for ATT U-VERSE service?
hi! u need to setup the wireless settings of your modem/wireless router in order for the wireless network adapter see ur wireless router, check ur wireless settings first. or try to contact ur isp provider who supply the model/wireless router..
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
