Question about Sony Xperia U ST25I Android OS v2.3 Cellphone with 3.5-Inch Touchscreen, 5MP Camera, 720p Video Recording, Wi-Fi and A-GPS Support - Unlocked Phone - No Warranty - Black/White
When i going to use camara display "Error camara not available" restart phone and tried so many times but not resolve please help me what can i do...
When I visited service centre they told me to replace backside camara.. and cost is 2100/- is this fare or not and if u have any other solution give me
    New Friend:
  • 11 Answers
I also used to have an xperia u and it also produced the same problem. First i tried to simply reinstall the whole operation system on it, this you can do through the sony update service software via your pc. If this does not help, (and this helped me only once) next time i simply took apart the phone, and tried to clean it checked the contacts within it (all the copper parts). After putting the device back together, my camera was working again. For the taking apart process you will need special tiny screw drivers.
Posted on Jun 20, 2014
SOURCE:
Memory storage is not working
low storage problem my phone is showing total space 12.28MB and free space 0.00MB not saving pictures,contacts,call history,messages and not connecting to the pc and giving the error in which stated that unplug restart and then connect your phone to the pc but several times i tried to connect but its not working.
i had restored it many times to resolve that problem but the problem is still present.
i had installed window in it but still the problem is present and annoying me.
HTC AT&T windows phone 7 surround
Aug 06, 2012 | HTC 7 Surround Cell Phone
My front camara not working what is problem i go
your software was missed.so upgrade your phone's software by an expert
thanks for rating good luck
Feb 12, 2011 | Nokia N95 Cellular Phone
When I try to start my camara , I get a msg. on the screen that says. ERROR OBJ. RESTART CAMARA
Try removing the memory card and see if that resolves the problem.
If it doesn't, remove the battery from the camera and leave it out for at least 24 hours. Hopefully this will allow any residual charge to drain and reset the camera.
If this doesn't work, there are more serious problems with the electronics at hand.
Mar 22, 2010 | Canon PowerShot SD790 IS Digital Camera
While opening n70 camara error is unexpected error
HI there, after turn on the phone don't open the camera.Just reset the phone from phone factory settings.After that restart the phone.When is completely ready for work then open the camera. I hope you naver face the problem.If you faced that problem again, then reinstall the phone software from net or nokia shop. Thanks.
Feb 25, 2010 | Nokia N70 Cellular Phone
Hi nokia n72 camera problem if click camera button means it will come unexpected error occurred. power off the device and restart is give this message please send me assistance on my e mail..
hi...dis is demon......
jus type dis code *#7307# and press call button ..it will format your cell and u ll be able to use camera.....plzzz vist
demon-qwerty.blogspot.com
Nov 13, 2009 | Nokia N72 Cellular Phone
Canon camara was dropped and now it reads e18. Camara still shows pictures on the display screen
Hi
The Canon E18 error happens when the lens gets stuck while trying to extend. When your camera was dropped the lens mechanism was damaged resulting in this error for a jammed mechanism.
If the camera is still under warranty you should see if Canon are willing to repair it. If not you can view this link which is a very good walkthrough with pictures on how the error was resolved with a Canon SD300.
As you can see from this the process is intricate enough and involves opening the camera so should only be attempted if you feel confident about taking it on.
http://members.shaw.ca/gregs_space/Canon_E18_repair_guide_for_SD300.pdf
Hope this helps. Please remember to rate my answer. Many Thanks.
Jul 28, 2009 | Canon Cameras
Sony DSC-H3 memory stick error
try inserting your **** on it.... maybe it will work.... and be an error free camara... thnk
Apr 15, 2009 | Sony Cybershot DSC-H3 Digital Camera
Lens error, restart camara issue in SD900
Hey GeorgiaPlum,
What is most likely happening is there is damage to the lens or the lens mechanism and you should have the camera looked at by an authorized service technician. I will say that digital camera repairs often exceed the value of the camera, but it can't hurt to get an estimate done. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 05, 2008 | Kodak EasyShare C613 Digital Camera
Error message
Try to send the fax at a different time when telephone line conditions have improved.
Or try to disable the ECM on yuor printer, to do that to these steps:
Press SETUP
Press DOWN until you ADVANCE FAX SETUP displays
Press OK
Press DOWN until ERROR CORRECTION MODE displays
Press OK
Press RIGHT ARROW to turn it off
Press OK
Then try to send new fax. If this does not resolved your issue pls try to go to your phone provider. Thanks
Oct 26, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Sony Xperia U ST25I Android OS v2.3 Cellphone with 3.5-Inch Touchscreen, 5MP Camera, 720p Video Recording, Wi-Fi and A-GPS Support - Unlocked Phone - No Warranty - Black/White Logo
Top Sony Cell Phones Experts
Marvin
Marvin
Lawrence Oravetz
antoniorojas
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
